Offset question.
Old Mar 4, 2012 | 10:26 PM
trance07's Avatar
Offset question.
Hello everyone,
I just wanted to know what the perfect offset is on a
2007-08 G35 V36, without having to roll the fenders???
Old Mar 5, 2012 | 12:09 AM
blnewt's Avatar
Need rim width, and intended tire widths.
Old Mar 5, 2012 | 12:11 AM
CandlestickPark's Avatar
ill Sedan
And ride height and camber settings.
Old Mar 5, 2012 | 12:12 AM
vqsmile's Avatar
and perhaps intended alignment specs (camber)
btw, fender are pretty much rolled from the factory. Just run your fingers along the edge sometime.
EDIT: guess candlestick types faster
Old Mar 5, 2012 | 12:13 AM
TomPeters's Avatar
Depends what look your going for. There are a lot of variables as well like wheel widths, amount of drop, amount of camber, tire specs, ect... Check out the Word file that Terry put together in the link below. You can see what others have gone with and then make a decision from there. After a lot of research I decided on 20x9 +25 in front and 20x10 +35 in the rear so I'll find out how I did in about 6 weeks. GL
https://g35driver.com/forums/v36-bra...ims-tires.html
Old Mar 5, 2012 | 06:18 AM
trance07's Avatar
Cool ty guys, ill look at that thread.
But yeah i was looking at a clean looking drop
And rim size. About a 2" drop, 20x8.5 F, 20x10 R.
Edit: oh tire size 245/35 F, 275/30 R.
If 19" 245/40 F, 275/35 R.
Old Mar 5, 2012 | 11:23 AM
soundmike's Avatar
Depends on your overall drop and camber settings, somewhere in the range of +20 to +34 for the front and +32 to +40 for the rears should work.
Old Mar 5, 2012 | 11:32 AM
TomPeters's Avatar
I actually changed my mind and am going to try +42 in the rear... +35 would be close to a 1/4" of poke I think. +42 should be close to flush
Old Mar 6, 2012 | 12:03 AM
bluedevils95's Avatar
Hello everyone,
The fenders are pre-rolled. +35 is stock set up
Old Mar 6, 2012 | 07:39 AM
soundmike's Avatar
It's +45 and +50 for the stock sport 18s, IIRC.
Old Mar 6, 2012 | 02:40 PM
apexi957's Avatar
+25 in the rear. Are you going to run stretch tires? I have a 245/35/19 in the rear
Picture Share
Feb 4, 2018 12:41 PM
TurTLe*
Sep 29, 2015 01:43 PM
AT23
Sep 15, 2015 07:44 PM
