transmission fluid
Old Jun 12, 2012 | 12:02 PM
SofaKingAzn's Avatar
transmission fluid
2007 G35x sedan, anyone know how many km until transmission fluid needs to be changed? and anyone know how to check the fluid? thanks
Old Jun 12, 2012 | 02:36 PM
b-dRizZy's Avatar
Great question im in on this
Old Jun 12, 2012 | 02:48 PM
blk35's Avatar
Check the dip stick while the engine is running every 480280.32km for tranny change.
Old Jun 12, 2012 | 02:54 PM
kool_yaar's Avatar
HERE you go, look at post#14 to see where the tranny fluid dipstick is... its behind the engine secured by a 10mm bolt i think
Old Jun 12, 2012 | 03:11 PM
mathnerd88's Avatar
Well, it depends on a lot of things. If you drive super aggressively you should change every 30k miles. If you drive mostly highway miles you can even get away with around 70k miles.
Just pull the dipstick up and sniff it- if it smells burnt then you should change it asap. If it still smells sweet, then it is still fine.
I changed mine at 60k miles and still running fine. I'm not even using Nissan specced transmission oil and am using some crappy one the nearby mechanic put in that is compatible with Matic-S/J.
Old Jun 12, 2012 | 06:26 PM
Phalanx's Avatar
Just in case anyone wants to change the transmission fluid, I have 2 quarts available here https://g35driver.com/forums/2nd-gen...n-matic-s.html
Old Jun 12, 2012 | 06:52 PM
b-dRizZy's Avatar
How many do you need when you do the switch ?
Old Jun 13, 2012 | 09:49 AM
Phalanx's Avatar
Some say they got 5-7 qt out just by draining it. I only got 3-4 qt out of the drain plug. If you disconnect the transmission oil cooler line, you will get about 17qt claimed by others not me.
g.spot
May 9, 2016 10:54 PM
f22raptor
Mar 18, 2016 08:50 AM
AL8782
Oct 3, 2015 10:26 AM
