Handling not that great.
Old Sep 24, 2012 | 12:19 AM
misfit77's Avatar
Is bad cornering standard issue on 2007 G35 Sedan Journey?
I finally tried the G on some high speed cornering....holy crap.
Handles aweful! My 2000 Golf with a 1" drop and a rear sway bar can out handle my G.
Is there anything low budget than can help our Gs?
Old Sep 24, 2012 | 12:20 AM
herrschaft's Avatar
Good tires
Old Sep 24, 2012 | 12:32 AM
misfit77's Avatar
running fairly good Bridgestones....traction was not a problem.
When shopping for tires in our sizes, nothing is cheap.
the car was just loose or sloppy could not stay in one lane.
Old Sep 24, 2012 | 12:35 AM
hurleyguys's Avatar
first off your golf weighs 2700 pounds as compared to 3500 pounds for your G. like herrschaft said good tires will make a difference. then maybe a drop and sways. but your G will never handle like ur golf.
Old Sep 24, 2012 | 12:40 AM
misfit77's Avatar
Sad to hear.
I love my G. Its actually my dream car.
Just glad I did not pay for a new one.
Old Sep 24, 2012 | 12:46 AM
jninja26's Avatar
Forget about the drop (springs). If your tires are as good as you say then the next steps are aftermarket sway bars (adjusted to preference) and coilovers (adjusted to preference). These two items will make a very marginal difference.
kool_yaar's Avatar
The front sways on the non-S are pretty small if i recall correctly, u can significantly improve handling in corners by either buying hotchkis sway bars that will make a HUGE difference or just get the used OEM sports front sway and that helps a lot too. My sports stock suspension handles high speed cornering very well even at the few track sessions iv had in the past.
Old Sep 24, 2012 | 02:18 AM
RedBaronK's Avatar
What tires do you have? Standard ones from Infiniti? List the brand and rating.. ie. 101w, 97v, etc. It can be found on the tire after the p225 55r17 or p225 50r18 if u have the sport trim.
Tires make a huge difference. I just replaced my tires and that annoying vibration and road noise disappeared, and the handling improved too.
Old Sep 24, 2012 | 02:35 AM
jninja26's Avatar
I switched recently from the original Bridgestones RE050's "2005" (YES ORIGINAL) 225/40/19 & 245/40/19 to Hankook Ventus v12 245/35/19 & 255/35/19, and I definitely notice a difference. My current setup is much quicker to turn (if that makes sense). Also, my Slip hasn't come on once, even with my new FI setup, unlike my 7 year old bridgestones which slipped with my NA setup on hard 1st/2nd gear sprints.
Old Sep 24, 2012 | 08:07 AM
mishmosh's Avatar
Handling shouldn't be that bad. Make sure your alignment is good and if you have a lot of miles, and if the ride is unsettled, your shocks/struts may be worn.
Old Sep 24, 2012 | 12:52 PM
stockae92's Avatar
There is a reason why the "Sports" trim level exists
maybe keep an eye on the wheel trade forms and pick up a set of 18" or 19" rims with good tires, and then start looking at suspension mod
this is a luxury sports (i.e. sporty) sedan, its not a light weight pocket rocket. you have to give up something for the luxury items.
"Sports, luxury or (lower) price" ... you can only pick two of them ;-)
Old Sep 24, 2012 | 12:58 PM
RedBaronK's Avatar
I'm curious as to how fast the OP was cornering this car in a turn. I rarely exceed 50mph on turns coming off ramps, and even with my old stock tires I never had issues....
Old Sep 24, 2012 | 02:12 PM
VMRWheels's Avatar
Originally Posted by herrschaft
Good tires
Agreed. Invest in good tires!
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
nissandrifter32
Dec 22, 2015 04:28 PM
c_elliott83
Sep 25, 2015 07:55 AM
G35-2004-mt6
Sep 11, 2015 04:16 PM
