Make my car faster
Old 04-19-2013, 03:21 PM
totopo's Avatar
Originally Posted by Kerry Garrison
Thanks, its a work in progress, I hope it helps some people. Always open to feedback on the article.
errrr, your discussion about top speed is not quite accurate. The top speed in the G35 is either ecu limited or wind resistance limited. Definitely not gear ratio limited, redline in 6th should be at 178mph (source).
If it's ECU limited, it's pretty straight forward. If it's wind resistance limited, it's more complicated involving wind resistance and gear ratios and rolling resistance. (ie where you first reach the point where wind resistance+rolling resistance = force at the wheels)
  #77
Old 04-19-2013, 04:20 PM
Kerry Garrison's Avatar
The G is ECU limited as far as I know. A 5AT will (stock) max at 6200 RPM and 140mph. I am not as familiar with the 6MT. Since an Osiris tune will allow a max RPM of 7200 RPM you can get more top speed from it. This tells me that its not wind resistance, its just a maximum engine speed issue.
  #78
Old 04-19-2013, 05:16 PM
totopo's Avatar
errr, using the gear ratios from: https://g35driver.com/forums/drivetr...explained.html
6200 in 5th gear in an 03-06 should get you to 170mph
the HR engine revs higher right? then 6800 in an 08 in 5th should get you to 168mph
So I don't think any are drivetrain limited. Look up your FSM if you think these posted gear ratios are wrong... On the freeway when you are going 70mp, is your tach closer to 2550 rpm or 3100 rpm?
  #79
Old 04-22-2013, 10:11 AM
billymaloney3's Avatar
anyone have a suggestion for black rims?
  #80
Old 04-22-2013, 10:28 AM
Must have black rims, that's easily 2-3 hp better than other colors.
ItsA..Gthing (04-23-2013)
  #81
Old 04-22-2013, 10:31 AM
? I know it doesn't add HP I was just asking for a suggestion on nice ones
  #82
Old 04-22-2013, 10:33 AM
There are a hundreds to choose from. You need to pick something that you like, not something just because it is popular.
  #83
Old 04-22-2013, 11:33 AM
http://www.gfchips.com/infinitig35.aspx does anyone know anything about this?
  #84
Old 04-22-2013, 11:58 AM
bluedevils95's Avatar
^ i say do a before and after dyno the same day to see if that really works
  #85
Old 04-22-2013, 12:29 PM
vqsmile's Avatar
Kid, the fact that you're even asking this question is the living proof of how and why these bogus companies can market this bulls@%t !
  #86
Old 04-22-2013, 11:18 PM
Glover997's Avatar
best part :
went from factory 275 to 325
  #87
Old 04-22-2013, 11:24 PM
I know my math sucks but isnt a 30 hp gain from 275 only going to be 305?
If you could spend $70 and bolt on 30-50 hp in 5 minutes, don't you think it would be the FIRST thing everyone would tell you to do? Just sayin....
  #88
Old 04-23-2013, 12:53 AM
chris_sims1981's Avatar
You remind me of the NUBE who just gets his MC licence and then buys a litre bike. He quickly becomes a RIP thread.
Lol ^ my fist bike was and is a liter bike
  #89
Old 04-23-2013, 08:14 AM
Blue Dream's Avatar
I drove ttrank's car solo
Received 1,486 Likes on 1,221 Posts
Not quite true. The DE motor has the speed limiter set at 155 and I have personally had my 05 5AT at 144mph and climbing before I backed it down (on a deserted Mexican highway of course). This was before I got tuned so I believe the first gen autos are capable of 150 or more given the right conditions.
  #90
Old 04-23-2013, 10:31 AM
All of the magazine tests from 03 all hit about the same 140ish mph top speed and the car is rated from the factory for 142 (per specs). So either all the testers never actually tried to reach a top speed (good bet) or it is actually capable of more (so as not to redline the motor). The gearing however should allow for a top speed at 6200 RPM of 155mph (according to other articles). I haven't found a stretch of road in SoCal long enough or empty enough to even attempt this.
Quick Reply: Make my car faster
