My headlights are jacked up!
Old Jul 9, 2013 | 08:48 PM
_RR_'s Avatar
Unhappy My headlights are jacked up!
My sedan has about 64,000 on it now and a couple weeks ago I noticed one of orange bulbs in my headlights was out. The bulb is about $16 online. How common is this problem, and how difficult is it to change the bulb? Should I expect the other one to go out soon or is this a fluke?
Also my housings are starting to look terrible. They have gathered some deep scratches that I made worse when I attempted to restore them. I've done some searching online but don't see any places just selling the lens.
Old Jul 9, 2013 | 10:51 PM
aktif8's Avatar
Incandescent bulbs blow - they dont last forever. No need to replace the other one until it goes, however (or just buy 2 led bulbs and be done with it.)
You cant buy just the lenses, but 07-08 housings are relatively inexpensive on ebay.
Old Jul 9, 2013 | 11:53 PM
blnewt's Avatar
You might be able to take it to a pro detailer and have them buff the hazing and scratches, then you could clear coat them followed by a buff polish. Should get them looking almost new if the scratches aren't too deep. I believe RaulCustom does this.
Old Jul 10, 2013 | 02:01 PM
Mike45's Avatar
You can just replace one light bulb.
As for the hazing you can sand it with low grit sand paper and polish it after and it will look good as new.
If they are not to bad you can use toothpaste on a towel and clean them, it will remove some of the hazing and yellowing
good luck
Old Jul 10, 2013 | 06:14 PM
vqsmile's Avatar
good luck
I can guarantee that if you sand your headlights and then polish them, you will undoubtedly remove a lot of yellowing, perhaps even all of it, and you can even get it to polish up as good as new again, B U T !!! . . . as blnewt mentioned, if you don't put a clear coat on them, you will forever be returning to buff out the yellow on your lenses, over and over and over again. Without a clear coat, the oxidation process will occur far more rapidly than when they were new; literally in months if they're exposed to a lot of sun.
.02
Old Jul 10, 2013 | 06:24 PM
Diode Dynamics's Avatar
If you are replacing one bulb, it makes sense to replace the other at the same time. Bulbs lose brightness over time, most people don't change them until they go out completely.
Also, you definitely want to replace them at the same time so the light output matches. Otherwise you'll end up having one side brighter than the other, or slightly different color.
If you are looking for LEDs, shoot me a PM and I'll get you taken care of!
Thanks,
Nick C.
Old Jul 10, 2013 | 06:31 PM
Footballmania32's Avatar
^ Great company right here. Love their products!
Old Jul 11, 2013 | 10:57 AM
_RR_'s Avatar
Thanks for the help all. I'm guess I'm gonna look around for a detailer in my area and see if they think the scratches can be sanded out.
Thanks,
Nick C.
Thanks, makes sense to do them both at once. Do you sell a LED replacement for that light or are you referring to the tail lights?
Old Jul 11, 2013 | 01:06 PM
They sell LED replacement products.
Old Jul 11, 2013 | 08:43 PM
_RR_'s Avatar
LEDs it is then! Thanks.
Old Jul 12, 2013 | 09:19 AM
You're gonna love them, I want to see pics when you put them in!
-Nick C.
jeffbdye
Jun 1, 2018 03:51 PM
Jeff T
Sep 30, 2015 02:00 PM
Batfinity
Lights
Sep 27, 2015 12:29 AM
