Air Intake Track Cleaning
Hey All.
I am about to embark on a 70,000 mile tune up.
This includes: motor and transmission fluid drain and fill, new serpentine belt, new tires, new air filters, new spark plugs, MAF, TB, and air intake track cleaning.
I have read up on how to do this and it all seems pretty straight forward.
My main concern is it seems like there is a 50% failure rate for users that have attempted to clean their throttle bodies. From error codes to erratic idles, the last thing I want to do is make my car worse.
That being said, I am fluent with the ECU relearn and idle-air relearn pedal procedure.
My questions are, if I know how to perform these resets, is there anything to worry about? Is there a dealer recommended way of cleaning the throttle bodies?
I would like to get it clean but I don't need it to specifically shine like new. I am OK with completely removing the throttle bodies and also have no problem with leaving them connected and cleaning them that way.
Does anyone know the best route for this? Any recommendations for cleaning the MAF sensors, is that even worth it or should I just stick to the TB cleaning?
Any input is greatly appreciated.
Thanks!
_Michael
Thanks!
_Michael
Michael fortunately this isn't rocket science. Since you're comfortable taking the TB's off, unhook your battery, remove the 2 power clips from the TB's and clean them with carb cleaner and Q tips BUT be careful to not touch or move the butterfly plates at all. Then re-install, hook the battery up and you're done. On the MAF's buy a can of MAF cleaner (I like CRC) at your local auto parts store, remove the MAF's and liberally spray the cleaner on the sensor wire, but don't touch the wire with anything. The cleaner will dry very quickly, re-install the MAF's and you're good to go.
HTH.
HTH.
So, I had previously performed the TB cleaning, but I never disconnected the TB. But, I was able to move the butterflies as much as I had to clean them. I didn't have any issues. I'm about to do this again in December. My question after reading this is, if I disconnect the TB, does this prohibit me from moving the butterflies? Or should I have not been moving them all along?
Yeah that is pretty much what I am wondering too. Some people say if you move the butterfly valve you HAVE to perform the idle-air reset procedure which I am super comfortable with.
Other people say, move the butterfly valve and yur gonna have to buy youself some new throttle bodies.
Anyone have success either way?
I have done this cleaning 3 times the same way. All times I move the butterflies as much as I need to. I just never disconnect the TB. So far every time works great. No issues. But, as always, perform at your own risk.
Can you elaborate on the "never disconnect the TB" portion of this?
Yeah, I never disconnect any of the wires from the throttle body. I do remove it from the intake, though. I'm just careful enough to not disconnect any wires, as was recommended on the original thread I read on here about cleaning the throttle bodies.
Hey All.
Thanks!
_Michael
Thanks!
_Michael
,02
So by doing it your way you're free to move the butterfly valve as much as you need to?
I just did mine, 98k on the clock they were FILTHY!
All I did was disconnect the battery, pull the TBs and leave the clips connected.
I moved the butterfly valves on both and cleaned away. Put all back together and all
was well.
was well.
Best way to clean your MAF is with sand. Most people take off their filter and put very fine sand in the intake tube, then have someone rev the engine over and over. The fine sand acts as a sandblaster and cleans your intake, MAF, and even ports & polishes your heads. You can pick up Intake Sand at autozone or most auto stores.
