P0057 Fuse location?
Old Aug 9, 2016 | 09:28 AM
mzancz's Avatar
Hi,
I am getting codes P0057 01/02 and P0057 P 02/02. From my research it seems that means Heated O2 sensor bank 1, sensor 2 and Heated O2 sensor bank 2, sensor 2. I found a diagram showing where these two sensors are. Before I change them I also read it could be the fuse for O2 sensor. Can anyone tell me where this fuse is, or provide a diagram? Thanks so much in advance!
Old Aug 9, 2016 | 09:55 AM
dookie's Avatar
Originally Posted by mzancz
Hi,
factory service manual:
http://www.nicoclub.com/archives/inf...e-manuals.html
fuse blocks are under the hood and on the left side of the dash (driver's side). I think there's also a fuse map in the car's user manual.
Old Aug 11, 2016 | 08:57 AM
mzancz's Avatar
No O2 fuse
I do have a fuse block next to the battery, and also next to the ebrake pedal. However none of these fuses are labeled O2, or anything that looks related? Pics attached. I haven't had a chance to look under the car yet to inspect the cables going to the O2 sensors.
Attached Thumbnails P0057 Fuse location?-img_4323.jpg   P0057 Fuse location?-img_4322.jpg   P0057 Fuse location?-img_4320.jpg
Old Aug 15, 2016 | 12:10 PM
dookie's Avatar
i don't think there's a fuse for the 02. did you search the service manual?
Old Aug 15, 2016 | 12:31 PM
yosip1115's Avatar
Guys, there are two fuse boxes in the battery compartment. The battery needs to be removed to access the one the OP needs, and yes, if you are tripping all four codes OP you probably popped the fuse. It has happened to me.
Old Aug 15, 2016 | 01:33 PM
mzancz's Avatar
Fuse box behind battery
Really, I didn't see anything in the service manual regarding this. I also didn't remember seeing anything back there when I replaced the battery but that was a few years back. If I remember there is not much space behind the battery before you are into the firewall, and that little plastic cover you remove to access the battery doesn't give you much room either. I can double check though. Do you have anything that shows this second fuse box?
Thanks
Old Aug 15, 2016 | 02:20 PM
telcoman's Avatar
Veteran: Army
Hi,
Have you tried the FSM?
http://www.nicoclub.com/service-manu.../Sedan/2008/PG
Telcoman
Old Aug 15, 2016 | 03:43 PM
dookie's Avatar
Originally Posted by telcoman
must be an echo in here....
Old Aug 15, 2016 | 03:46 PM
yosip1115's Avatar
http://images.lmgtfy.com/?q=fuse+box+behind+battery+g35
I had to
Old Aug 16, 2016 | 11:04 AM
mzancz's Avatar
Found it
Sorry, I found the third fuse box location. I was able to just loosen the battery hold down bracket and slide the battery over a little after removing the windshield cowl cover.
The O2 fuse was not blown, but I replaced it with a spare 15a just to be safe. Same issue, so I will inspect the O2 sensor wires, and if they are good replace the two O2 sensors, then then hopefully that will be it.
Thanks again guys
Old Aug 31, 2016 | 09:19 AM
mzancz's Avatar
O2 sensors replaced!
Two of the wires going to the one O2 sensor were completely deteriorated. I replaced both downstream O2 sensors with two new Denso sensors. Took under 30min total. Thank for all the help and sorry for my ignorance with my questions.
Old Aug 31, 2016 | 09:26 AM
yosip1115's Avatar
Glad you got it resolved. I was up all night trying to fix this same issue one night with a dyno tune appointment scheduled for 9AM the next day. It was hectic until I found the issue.
Old Aug 25, 2020 | 11:16 PM
Kinx Soccer's Avatar
coupe
O2 sensors
Hey man I would just like to know where u purchase ur o2 sensors because im worried they won’t fit my g35 I see lots of people run into that problem. Also does it matter if it’s a bank 1-2 sensor or is it the same thing?
Old Apr 29, 2025 | 09:11 AM
phanyom's Avatar
I need the location of this sensors
Where is this sensors located
Old Apr 29, 2025 | 09:46 AM
dookie's Avatar
Did you look at the service manual linked above?
Worin
Sep 30, 2020 12:19 AM
eliaswhufc
14
Jan 28, 2020 11:43 AM
korfak
Nov 23, 2015 02:14 PM
Al Janinny
Mar 30, 2013 11:01 AM
512G
Dec 8, 2011 05:52 AM
