Prospective buyer questions about the engine reliability
Old May 12, 2018 | 02:47 PM
telcoman's Avatar
Veteran: Army
Originally Posted by zerosl
Hi all,
I have been in the market for a RWD Manual sedan, which is becoming quite the unicorn these days. I have been looking for a g37 sport sedan for a long time because of the newer and more reliable engine, as I've heard some bad things about oil consumption on the 3.5 VQ engines.
I really could use some better qualified opinions and experience on the matter.
I want to know how reliable the engine is on the 07-08 G sedans. My research tells me that the oil consumption problems are more common in the VQ35DE and may have been addressed in the VQ35HR?
If anyone can confirm, or share their experience, i'd appreciate it.
I traded in my 06 G35 6 speed manual at 171796 miles. And yes it frequently burned 1 quart of oil per 1000 miles and I did 53 oil changes changing oil every 3500 to 4k miles.
It was a very reliable vehicle for anyone that checks their oil once a week.
I also previously owned a 1974 RX 4 Mazda with a rotary engine that also used oil to lubricate the engine seals . Many engines were destroyed by many who never checked their oil and essentially killed the rotary engine in the United States which was very light and powerful.
Whatever used vehicle you decide to purchase spend the $150 or so to have the vehicle thoroughly checked out by an Infiniti dealer to run the VIN number and give you a vehicle service history. There are many previous owners that leased and failed to do timely oil changes. Any engine with evidence of sludge is not going to give you a reliable experience.
Good luck
Telcoman
Old May 27, 2018 | 11:18 PM
cleverclaire's Avatar
Originally Posted by treacherous
yearly oil changes.
Huh? Seriously? Even with only 5k-7k miles a year I would change the oil every 6 months. But that is just me.
Old May 27, 2018 | 11:25 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Yearly is fine, oil has a shelf life of between 5-10 years depending on a great many variables. The biggest reason for recommending yearly changes as opposed to more than 1year is mostly so people don't forget about it.
Old May 28, 2018 | 04:57 AM
ScraggleRock's Avatar
I don't trust that for a minute.
It probably has a "sealed" shelf life, but like milk, once it's opened it's susceptible to oxidation and any expiration date goes out the window. And yes, there are many variables, but heat is the biggest (especially when subject to an immediate cooling cycle - that's why short trips are hell on your car and you can't trust low milage).
Oil doesn't actually break down (which is why it's infinitely recyclable), but it's the detergents that degrade, oxidize and evaporate. Those things are not controllable; it's the engines that have gotten better; oil has too but not at the same rate. It's like the vegetables are the same, but we've got better Tupperware. But still, I'm not going over 5000 miles or 6 months.
Old May 28, 2018 | 11:07 AM
Hall Stevenson's Avatar
Discussions (or debates) about oil change intervals and so on are a waste of people's times and efforts. No matter what one's opinion is, some will argue it's wrong. No matter what oil brand, viscosity, synthetic vs blend vs conventional, you'll get arguments about why it's wrong. I've found that it's best to keep your brand, interval, and so on to yourself....
Old May 30, 2018 | 02:41 PM
stockae92's Avatar
'08 G35s with 6MT, at 79k miles, doesn't burn oil, conventional oil change every 4500 miles.
Old Jun 9, 2018 | 10:12 AM
sonors's Avatar
Originally Posted by ScraggleRock
The model you're looking at doesn't have unusual oil burning issues. Most of the oil burning issues were with the rev-up motor (05-07 6mt coupe and 05-06 6mt sedan). The regular DEs never had a recall. These motors are pretty bulletproof; it's the suspension that you should concern yourself with.
Just for reference, you have 3 motors in the G35:
VQ35DE: all 03/4 cars as well as all auto coupes 03-07 and all auto sedans 03-06. No recall for oil burning *some people claim oil burning*
VQ35DE rev-up: 05-07 6mt coupes and 05-06 6mt sedans - heavy oil burning - situational recall
VQ35HR: 07-08 sedans - most issues were worked out here. No oil burning issues known.
^^^^^this^^^^
My wife drives a 2003 Sedan. I drive a 2008 sedan. Never add a drop between 4K oil changes on either.
Old Jun 16, 2018 | 11:23 AM
Justice06RR's Avatar
Good to know, thanks.
You know that some cars do 10k oil changes right?
So if you drive 5-7k per yr, you should be fine; that's actually not much. That's about how much I drive my G (~7k/year). I could probably do one oil change per year and just add a quart or 2, but since the car is older and burns oil I tend to follow the routine intervals at 3500.
Now if your car sits for 3-6months out of the year, then yes change it more frequently. But for vehicles that are driven routinely and maintained, it shouldn't be an issue.
Old Jun 16, 2018 | 01:02 PM
Newer cars than 07-08 Infiniti cars do but even Infiniti indicates either 3750 or 7500 (Schedule 1 and Schedule 2). They also base this on conventional oils. Can you run longer intervals with confidence ? Sure. Use synthetic oils ? Sure. If you combine highway miles with synthetic oils, you can probably go 10k miles in an 07 or 08 G 35 too. I wouldn't personally.... 7500 would be the most I'd go.
I've seen multiple oil analysis in the 10k range that show ZERO issues. One went 12k and the analysis company said try 14k. The owner describes their driving as 70% city driving too. This thread (report doesn't show up) is for 10k miles on the previous generation DE engine. Good for them !
limenuke
Mar 29, 2013 11:33 AM
wrxsti04
Oct 31, 2010 09:22 AM
AuAltima3.5
Oct 24, 2010 09:29 PM
Typhoon
The M-Spot
Mar 7, 2006 04:05 AM
Tim Whatley
13
Feb 10, 2006 01:13 PM
