07 Sedan Trunk Wont Lock
Old Jun 29, 2018 | 12:02 PM
03ncleosedan's Avatar
So I have tried searching for anyone who had this problem to no avail. I cannot secure my trunk. The latch will not lock when the trunk is closed. Interior switches work, Im getting power and the fob activates the lock. Its almost as if the upper latch is too short to reach the lower striker latch. Any help would be greatly appreciated.
Old Jun 30, 2018 | 12:21 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Take the trunk lid opener switch off and inspect it for proper operation, it's probably broken.
Old Jun 30, 2018 | 01:53 PM
I push it and it unlocks the trunk, so its working. Is there something specific I should be looking for with it?
Old Jun 30, 2018 | 02:02 PM
cleric670's Avatar
BANNED!!!
Ohhh I misread what the problem is, so the trunk latches just fine but won't actually LOCK?
Old Jul 1, 2018 | 03:57 PM
Yeah man, its crazy. Interior switch works, fob does as well. Unlocks all day, but wont latch.
Old Aug 3, 2018 | 11:08 AM
B1teDaBull3t's Avatar
I have the same problem. It occurred when my battery died while replacing a rear tail light ballast. The trunk was still open when the battery died. I don’t know how to fix it. I just hope this comment helps
Old Aug 3, 2018 | 11:51 AM
dohturdima's Avatar
Doesn't hurt to check whether the wires in your trunk harness relay are all intact. The wires can be frayed with time & use and you can lose partial function of locking your trunk depending on which wire has been completely cut. I spliced several wires in my existing relay several times, and then just replaced the entire thing. My issue started with the trunk only opening with the key fob or in-cabin switch (but not when pushing the rear trunk button), and eventually progressed to trunk not latching at all.
Old Sep 16, 2018 | 01:37 PM
Well, ironically my battery is dead now so I will check that out. Tnx.
Old Sep 16, 2018 | 01:38 PM
I'll check into that, tnx.
Old Sep 29, 2018 | 12:29 PM
Mr.GEE's Avatar
20 Year Member
Trunk will not lock if the key fob is in the car. If you have more than one, make sure they both are out of the car. My wife had dropped the key fob between the seat and center console, drove me insane on why I couldn't lock the trunk when I had the extra Key fob in my hand.
tony011
Jul 18, 2017 09:27 PM
stoofpilot
Jul 6, 2010 03:41 PM
djayx1
Dec 31, 2009 03:30 PM
potmilkz
Jun 1, 2009 08:57 PM
kyle5486
Aug 27, 2008 02:43 PM
