TPMS light flashing, blinkers turning on, and beeping noise?
Old Jul 2, 2018 | 12:47 AM
Kb24great's Avatar
Hey guys, I am pretty sure my TPMS sensors are bad, but just wanted to clarify.
When driving, the TPMS light will turn on and flash, then my blinkers would turn on automatically for like 2 seconds, and then when I become to a full stop my car makes a beeping noise like I just locked the doors with my remote. From what I read, the flashing TPMS light means I will need to replace the sensors, but I never read anything about anyone else having their blinkers turning on randomly and a random beeping noise?
Old Jul 2, 2018 | 09:10 AM
Hall Stevenson's Avatar
Like you, my understanding was the TPMS light will FLASH when the sensor(s) are dead (battery). If the flashers and the beeping just started happening at the same time, maybe they are linked in order to get the driver's attention better.#s3gt_translate_tooltip_mini { display: none !important; }
Old Jul 2, 2018 | 10:47 AM
Urbanengineer's Avatar
In other words check your tire pressure first and go from there .
Old Jul 2, 2018 | 10:49 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
That's not normal behavior, I would check the battery ground and the chassis side of that bonding jumper, also the BCM harness and ground. Possibly a failing BCM but you need to rule out other electrical problems first.
Melo5812
Jan 17, 2018 11:55 AM
amandag35x
Nov 5, 2012 08:45 PM
DJ Hellfire
Jan 4, 2011 08:28 PM
G35scBkNy04
Sep 30, 2005 05:13 PM
Triji
Nov 13, 2003 06:33 PM
