Coolant in transmission.
Old Aug 20, 2019 | 09:25 PM
nickt921's Avatar
Does anyone know if the 08 G35 auto has the issue with the coolant mixing with the transmission fluid? I hear it’s a big issue with other Nissans with the RE5R05A Transmission.
Old Aug 21, 2019 | 11:35 AM
scumbagsleeper's Avatar
1990 Mustang GT - 351W Lightning bored/stroked 383CI TFS heads 78mm Turbonetics huricane
That happens when your ATF loop / cooler built into the radiator leaks internally. Then the 2 fluids get mixed or shared. I have 2x V35 cars and 1x V36 and haven't had that issue yet but have read about the problem in transmission service bulletins. It would be nice to know what model / years of these radiators are affected by this problem.
Old Aug 21, 2019 | 12:05 PM
nickt921's Avatar
I know it is very common with the older Pathfinders and Xterras. Good to know that you didn’t have the issue. I believe the transmission cooler on the G is a different design so it doesn’t seem to be as common on them.
Old Aug 21, 2019 | 01:55 PM
FreshLikeAG's Avatar
The Nissan's had a problem from 05-10 or something like that. Like many things, Nissan failed to recognize it. You can bypass the radiator and add a separate cooler for transmission. It's the one thing I actually fear. No matter how good you treat the car, it's hard to prevent something catastrophic like that
Old Aug 21, 2019 | 09:05 PM
Triton3.5's Avatar
I thought the G sedans already had a auxiliary tranny cooler? down in the right front lower grill area, i am pretty sure mine does, all though my car is an X. Because it certainly won't be a power steering cooler, would it?
Old Aug 21, 2019 | 09:37 PM
It may. It's been forever since I've had my bumper off but I thought I read that only certain markets had the aux transmission cooler for the DE engines at least
Old Aug 22, 2019 | 09:18 AM
That's the power steering cooler on the front passenger core support. If you delete the internal cooler (the radiator/trans setup) and use an external you will have cold transmission fluid in the winter for a lot longer warm up cycle. The radiator actually warms up the trans in the cold. I would be real careful doing that if you live in a cold climate area and don't let it warm up for a lot longer period or you may wear the AT clutches faster. The trans does have a internal temp sensor and boosts the line pressure in cold conditions but I wouldn't push it until it's at operating temp.
Old Aug 22, 2019 | 08:55 PM
Urbanengineer's Avatar
Only an issue on the auto trans, afaik.
Old Aug 23, 2019 | 11:10 AM
Yes, the manual transmission cars don't have the ATF cooler loop inside of the radiator. I've see a few people buy a radiator not thinking about transmission type and get one that won't work with an auto trans since there is no cooler built into most manual trans radiators.
Old Jan 10, 2021 | 01:55 PM
Chris Pope's Avatar
G37
If it’s on the passenger side pretty sure it’s a power steering cooler. Definitely if it’s just a small little guy
08G35xsedan
Apr 16, 2019 07:41 AM
saskicker32
Aug 11, 2015 02:12 PM
Phenomenon9
Aug 9, 2015 01:34 AM
Awakened2001
Aug 25, 2014 05:00 PM
josetoyota
Jul 13, 2010 08:07 PM
