2007 G35X AWD Suspension Upgrades
Old Jan 23, 2020 | 06:55 AM
G35andBeyond's Avatar
G35X Sedan
Good Morning Folks,
I drive a 2007 G35X AWD sedan with 166K miles on it. I bought it used at 73K. I've installed a Stillen gen 3 long tube intake and an Ark grip exhaust system. Recently Ive noticed the drive is becoming harsh. To the best of my knowledge, no suspension upgrades/replacements have ever been done besides a wheel bearing or two. The car runs great and there's no major mechanical issues yet (fingers crossed).
I've gone thru a few of these threads for some guidance but I'm still in the weeds here. I'm not mechanically inclined but I prefer to buy parts myself and then have them installed (slightly cheaper). Eventually I'd like to start buying tools and working on the car myself but that's a way off (family, work, etc).
I want to keep this car for another 50k miles ideally. From what I've seen on these threads is that it's best to do a complete suspension overhaul at this mileage especially if everything is still original stock. I know I should replace the shocks and struts but I keep reading about control arms, bushings being worn, coilovers are cool, sway bars and so on.
Needless to say I jumped too far into the well and I need some guidance here. I see this as the last major upgrade I'd do on the car. I could afford maybe 1,500 to 2,000 on parts so what should I focus on here. Any help or advice would be greatly appreciated. Thanks!
Old Jan 23, 2020 | 08:46 AM
eazdaskeez's Avatar
Rockauto is gonna be where ya wanna go, kyb shocks all around is gonna change ride back to the factory comfort. For other components try to stick with moog if money allows.
Old Jan 24, 2020 | 09:16 AM
G35X Sedan
Thanks for the advice. I'll check it out more thoroughly this weekend. Only a few of the moog components looked pricey but overall they seemed reasonably priced.
Old Jan 28, 2020 | 09:40 AM
G35X Sedan
Parts
Took your advice, kyb shocks on all four corners, moog control arms, upper arms, mounts, mevotech sway bar links, and a hotchkis sway bar kit. The only major component I didn't purchase were new springs. My main question is whether it's necessary. The car appears sag a touch in the rear but all four springs appear to be fine. So would you replace the springs since I'm gutting everything else anyway and if so, what kind? Im not opposed to lowering the ride but I want to maintain a decent clearance. Thanks!
Old Jan 28, 2020 | 12:33 PM
Joenavy85's Avatar
G35x Base
I've looked around at numerous G35 sedans and have come to the conclusion that they just look that way. This summer when I have her torn apart for engine work I'm planning to also replace all my shocks and install 20mm spacers for the springs and shocks on the back. This will even out the fender gap, which just looks goofy at this point.
Old Jan 28, 2020 | 02:08 PM
G35X Sedan
Haha yea goofy is a good description for it.
Old Apr 10, 2020 | 07:12 PM
DPL8's Avatar
Infiniti G35x Premium Package Luxury Package
I have an 08 running with literally stock suspension and just an upgraded 370 Nismo RSB and the car corners so much better
Old Apr 10, 2020 | 08:10 PM
Joenavy85's Avatar
G35x Base
Is it an aftermarket RSB or straight off a 370z? The RSB is something I've been looking at swapping, but not wanting to drop a lot of cash on it. Ebay has a 2017 370z RSB for $129,which is an intriguing price to me.
Old Apr 10, 2020 | 09:03 PM
DPL8's Avatar
Stock 370 nismo RSB
Old Apr 10, 2020 | 09:09 PM
Joenavy85's Avatar
G35x Base
Stock 370 nismo RSB
Good to know, too bad the front sway bar isn't also compatible.
Old Apr 14, 2020 | 09:15 PM
Joenavy85's Avatar
G35x Base
Although, maybe somebody will know if the front sway bar of the xS is bigger than that on a regular x. If I'm upgrading one, I might as well upgrade the other.
Old Apr 14, 2020 | 09:20 PM
DPL8's Avatar
they are the same, the X does get the thickest front sway from the factory.
If you add a thicker front bar it’s just gonna make it understeer more.
Old Apr 14, 2020 | 09:25 PM
Joenavy85's Avatar
G35x Base
No oversteer with the NISMO RSB?
Old Apr 14, 2020 | 09:30 PM
DPL8's Avatar
With just the nismo RSB it def rotates more
Old Apr 14, 2020 | 09:31 PM
Joenavy85's Avatar
G35x Base
Just wanted to make sure it wasn't crazy overall. I'm sure it will take a bit to get used to it
martiangiant
Nov 27, 2018 05:11 PM
slcg35x
V36 Brakes, Suspension, Wheels & Tires
Jul 21, 2016 04:20 PM
TT C6
34
Oct 23, 2007 11:39 AM
seddon
Aug 29, 2006 10:46 PM
aam6906
Jan 10, 2005 05:07 PM
