Transmission Issues
Transmission Issues
Hi Everyone.
I’m having an issue with my transmission. Its the 5 speed auto. Every time I’m in 3rd gear, once the engine rpms go over 3k the transmission feels like it’s slipping. Its not a strong slip but it’s definitely noticeable only in 3rd gear. Anyone know anything about it?
I would drain/fill the transmission so you can get a really good look at the fluid and not just the microscopic amount that comes out of the dipstick. Just to verify you are checking the transmission fluid with a hot transmission right? So basically you go for a drive, come back, cycle through every gear, put the vehicle in park then while the engine is running you check the fluid right?
uaeg35
V36 Engine, Exhaust, Drivetrain & FI
May 16, 2010 12:53 PM
