Shifter Park Pin
Old Mar 18, 2022 | 11:52 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Here's that video Speedkar made. He does a full disassembly of the shifter, might help shed some light on why that pin bent.
Keep in mind I think the G he disassembled was a 2004??? Should be essentially the same shifter as you V36 though.
Old Nov 10, 2024 | 05:59 PM
Nikstar2024's Avatar
Infinity loaded.
Gear shift not going into park either.
Originally Posted by 909
Bend it back bro. But be careful. Let us know how it works out.
Maybe someone else knows. We can't be the only 2 members who have had this problem.
no you're not. Mine is sitting outside of work doing the same freaking thing. Im trying to figure out how to get the gear shifter thing to pop off so I can find the part. I am a female, so any advice would be greatly appreciated....
Old Nov 11, 2024 | 04:44 PM
MaLPoPieS's Avatar
Jaguar XFR-S
I can relate to this issue as i'm the one that caused it in my G.
Few months ago, i was diagnosing the looong engine restart times and i got so fed up with that G that i literally grabbed the shifter, pressed the brake pedal and it wouldn't release so i pulled it VERY HARD and it went into D and i heard a crack. I was too pissed off to think straight so i pushed it back into P and it wouldn't go all the way.
I left it like that overnight to cool off and the next day, took the top cover off along with side console covers and found that metal pin that goes left-to-right through the shifter was bent like a bow. I took a 8mm socket and bent it back as straight as i saw and honestly, the shifter works hell of alot better than it did before i bent it!
So bend the metal rod forward a bit and it will go into that slot.
Unless, you have something that fell into the shifter assembly and is blocking it from being locked in park..
Old Nov 11, 2024 | 08:04 PM
Infinity loaded.
super appreciate a reply!! i was at work last night and i had the whole thing torn apart lol. I tried EVERYTHING to push that little piece back and I don't know if I'm not strong enough or needed a different tool. But, it wouldn't move. I also have the water issue on the drivers side and am almost wondering if it's basically fried my damn car. I don't want to pay 1600 to have that fixed! So aggravating!!!! I'm ready for someone to just smash and grab it lol. It doesn't even have 100k. And I've done all maintenance required. It's a 2013 and I'm not sure if I may just clean it up and slide by with a quick sale to some kid wanting to race it. Lol
I'll try another tool because it's clearly not going in all the way and catching.
Old Nov 11, 2024 | 08:37 PM
MaLPoPieS's Avatar
Jaguar XFR-S
That steel rod is pretty hard and strong, it's Nissan security at it's best (not to forget the bypass hole) but that rod is fixable, just find a 1/4" long socket that will fit with a extension on it and hold the shifter and with the other hand, bend it. It will bend since it's already bended you just need to get a grip on it. Remove the side center console plastic for better access. It will feel as if it's gonna break but it won't, it didn't break on mine..
As for the water intake; Assuming you have a sunroof (i hate sunroofs!!!) most likely the drain tube detached from the drain port right above your head. Remove the handle above your head, peel back the door moulding and pull down the upholstery to see if the tubing 'shrank off' like mine did. If it's attached, then you'll need to do a the Sunroof Bypass procedure, it's a common issue where Nissan put 1/16" drain holes for 3/8" tubing..
Passenger side has the Body Control Module which is right underneath the sunroof drain plug that clogs up and lets the water flow right over the BCM which will provide you with a spectacular Christmas lights show on your dash along with automatic wipers, blinkers, blower controls and bunch of other stuff.
o0amazinazn0o
Aug 10, 2007 06:07 PM
mattyd54
Jul 11, 2007 01:13 AM
G35Tuning
Drivetrain
Dec 15, 2006 12:29 PM
Geeman
Interior
Oct 10, 2002 11:30 AM
