Help to many Miles ? Mod the car ?
Old Dec 25, 2022 | 06:37 PM
Don't@me's Avatar
G35X
Hi, I have 160,000 miles on the dash an plan on modifying my G.The car has been well taken care of through the years & maintenance is great I've had no problems. Just want some feedback, should i sell it & get one with lower miles or...? * also i do plan on keeping it naturally aspirated. i know problems will happen regardless how many mile just ant feedback.
Old Dec 26, 2022 | 04:24 AM
Scorpi0's Avatar
Not sure where youre at, but youll probably have a hard time trying to find one of these for lower than 160K miles.
If it runs fine then keep it. And check your oil level every 500 miles cause these cars tend to burn a lot of oil. I have to add a quart about every 700 miles.
Old Dec 26, 2022 | 06:16 AM
Loki24's Avatar
Dark Blue X, FX35 wheels painted black, BC Coils, tinted windows
Drop the oil pan and check for broken gasket pieces in the bottom of it.. The oil gallery gasket inside the front timing cover is notorious for crumbling and then causing low oil pressure. The bits of gasket often fall down into the oil pan and sometimes can be pulled up into the screen on the oil tube that reaches down into the oil pan. This could starve the engine and seize it up. Good luck 👍
Old Dec 26, 2022 | 09:33 AM
909's Avatar
909
Your mom's boyfriend
Don't fix it if it ain't broke. But if you find a great deal on a newer / lower mileage car and you can afford it , then go ahead and treat yourself .
Old Dec 27, 2022 | 10:53 AM
No Boost's Avatar
G35x/Cayman S 3.8L
I purchased a bone stock X at 129,000 miles and FBO'd it with a tune at 133,000. So far, so good at 136,000. I change the oil every 4-5 months religiously given the car's high mileage. I'm just one example but proof that these VQ motors are stout when well maintained.
Old Dec 28, 2022 | 01:56 PM
909's Avatar
909
Agreed. My X is well over 250,000 miles with absolutely zero engine issues.
Tone84
Jan 15, 2016 03:06 AM
Infiniminime
Jan 27, 2009 01:29 PM
eurodre
Mar 17, 2008 05:25 PM
isbn1975
May 1, 2007 01:27 AM
themanofwisdom
Feb 3, 2006 02:01 AM
