G35 Limp mode every now and then
Old Dec 5, 2025 | 06:20 AM
Darelle700's Avatar
g355
Got limp mode yesterday after a long drive but this time the vdc and slip light came on and my dashboard started flickering. a couple months ago i already replaced battery have new negative cable due to corroded and movable ,and a new positive terminal end (not the entire fuse block) the car was acting like it wanted to cut off i cut it off and cut it back on and its starting slow (one time before it cut it off and the battery died) so maybe new battery and new terminal gave it some backbone to still crank is it my APS? Or camsensors or maf ? It feels like its a battery problem maybe getting the entire positive fuse block to see if so? Sorry for rambling just looking for any insights on what it could be given there are a lot of options here also no codes on my scanner
Old Dec 5, 2025 | 09:24 PM
MaLPoPieS's Avatar
Jaguar XFR-S
Engine sensors cause limp mode, so i'd focus on that. I got limp mode only once when my cheap Hitachi cam sensors failed.
ECM controls the charging system using the IPDM so check the 3 pin alternator plug. See if the alternator is wet from power steering oil..
Old Dec 13, 2025 | 09:49 AM
Darelle700's Avatar
g355
sorry for late response but codes finally appeared on scanner as i suspected camshaft sensor bank 1 and crank shaft sensor i ordered all 5 from z1 (crazy expensive wtf) now this might seem dumb but i know each cam has specific bank and one is exaust and intake cam the question is with the new cams do i just switch them all out? Like how can i tell with the new cams which is which? Or does it not matter
Old Dec 13, 2025 | 11:14 AM
MaLPoPieS's Avatar
Jaguar XFR-S
Here, read my thread on this and make sure to get the right ones: Long and rough warm or hot restarts
All 4 camshaft sensors are the same in the VQ35HR engine.
Old Dec 13, 2025 | 02:54 PM
99zx2turd's Avatar
what was the actual codes you got? entering limp mode is bad news. hopefully it's not something mechanical.
Old Dec 18, 2025 | 01:01 AM
Darelle700's Avatar
g355
after installing cams car is dead and started very sluggish with battery starter (no dash lights at all low/sluggish idling and ends up cutting off after a few minutes when i put the car in “ON” position the only lights that come on is battery but it is very low barley illuminates my only guess is my alternator connecter? Given i had to splice on a different connector when i changed alternator 6 months ago ? but i have never had any issues with cranking or electrical for that entire time until now, only 2 of the 3 pin wires are crimped btw one just has twist and electrical tape over but also does it look like the positive cable wire harness thats connected to the alternator looks damaged here? I cant really tell from there the plastic is so brittle i will pull the harness up the weekend to get a better look but was wondering any suggestions here
suncookie
Feb 24, 2024 10:36 PM
pachieng
Sep 28, 2011 01:50 AM
KyG35Driver
Dec 22, 2010 06:26 PM
WhosRich
Oct 23, 2010 08:04 PM
DeadCellShadix
Mar 11, 2008 09:10 PM
