Gas Door Sunken in
Old Feb 23, 2026 | 10:52 PM
haolejonah's Avatar
Originally Posted by G2B35AGN
It’s also possible that the frame that holds them got bent when the door got pressed in too hard. You might first check to see if they are bent. If so, try to bend them back into position, but don’t lever on the fuel door; use needle nose pliers or similar to grab and bend. Don’t use a screwdriver against the fuel door.
Okay I will. I appreciate your help
Darkmark7
Oct 8, 2010 01:54 PM
DHCrocks
Apr 30, 2009 02:08 AM
Nate_G35c
Dec 10, 2008 11:11 AM
NorCalifG35
Mar 28, 2007 08:32 AM
thfx
Mar 21, 2005 07:19 PM
