windows roll down by themselves?
Old Feb 26, 2022 | 10:06 AM
  #31
infinityfx35sl's Avatar
fx35
I had same problem
Had the exact same problem, I tried all suggestions above and they didn’t work. The driver side window motor had to be replaced, it’s cost 600$cad for the part, couldn’t find a used one.
Old Feb 26, 2022 | 10:44 AM
  #32
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
That sounds like dealership prices. It shouldn't be more than $150 USD for the motor unless you are also paying for labor to have it installed. Even then $600 CAD sounds a bit high since it takes less than 1 hour to replace the window motor.
Old Feb 28, 2022 | 03:18 AM
  #33
LAAllday's Avatar
Inifinity fx35
Quick Question
Originally Posted by Rozzaydutch
this worked for me
I haven’t tried your advice yet but will tomorrow… I was just curious as alot of people reference the key faab yet i ruined mine in the wash a long time ago, and so i dont use it. nor do i lock my car (shh!) and it happens at work or home or wherever… even though the broken faab is nowhere around could that still cause it do you think?
Old Feb 28, 2022 | 09:18 AM
  #34
fx35
no it’s not the Faab, I removed the battery and still didn’t solve the problem. The motor is the issue
Old Mar 21, 2022 | 05:47 PM
  #35
TripleJBVBT's Avatar
2005 Infinity G35 X Drive 4 door.
How do you take out the window fuse ???/? PLEASE let me know!
Old Mar 25, 2022 | 06:43 PM
  #36
cleric670's Avatar
BANNED!!!
Window motor fuse does a lot more than just the windows. If it's a sedan you can roll the window up all the way then unplug the window motor harness, if it's a coupe you cannot because it has to drop to clear the sash every time the door opens.
Why don't you just replace the window motor though?
thepro78
Dec 9, 2011 12:42 AM
G35Wealz
Dec 22, 2008 11:47 AM
Ericb410
Jul 29, 2007 03:14 AM
French87
Apr 13, 2007 06:02 PM
yoyopol2000
Dec 23, 2004 07:35 PM
