o2 heater problems please help
Old Oct 14, 2010 | 04:50 PM
aBLUEg35's Avatar
so i have a 2006 vortech g with berk hfc's and borla exhaust and its throwing a code for both bank 1 and bank 2 primary o2 heaters. the code has for the most part been on since the vortech was installed and tuned.
do i buy new o2's? are there any heavy duty o2's on the market? and why would both go bad at the same time?
i just dont wanna spend 350$ than have them get destroyed again.. HELP
Old Oct 14, 2010 | 06:54 PM
aBLUEg35's Avatar
bump! i need an inspection sticker!!!!!
Old Oct 14, 2010 | 11:55 PM
G35MR2's Avatar
What codes are you getting? P1271 & P1281 ? Did your car go into LIMP mode? With respect to your question I believe Bosch sensors are the best way to go.
Old Oct 15, 2010 | 08:11 AM
M302_Imola's Avatar
You could try O2 sims...this would def. be the cheapest solution.
Old Oct 15, 2010 | 08:21 AM
Metalp3n's Avatar
My car pops a CEL for 02 sensors whenever it rains severely around here and the highway gets flooded while I'm on it. This causes my cats to drown basically, the joys of being low. I've always parked my car on a steep incline afterwards, exhaust opening facing down the incline and left it for a bit. Then reset the CEL and no more 02 problems.. You never mentioned rain or water, so I do not know if this is your issue as well, but I figured just in case I would share my experiences with my 02 sensors and CELs. I have been experiencing this for around 3 years now. Never swapped my 02 sensors, just let them dry out and reset the CEL.
Old Oct 15, 2010 | 07:23 PM
aBLUEg35's Avatar
my car doesnt see any water (other than a bath now and then lol) and i dont know the exact cel codes. i do know that its both left and right front o2 heaters.
like i said i dont mind puttin in new o2's in but i just dont want to mess those ones up too as i only have 26,000mi on my coupe so they should have lasted longer than that.
Old Oct 15, 2010 | 07:26 PM
aBLUEg35's Avatar
also the cars not in limp mode. it runs just fine other than that. i was also thinking that maybe it was some kind of wireing issue between my car and my AEM fic? any one else ever hear of something like that happening?
Old Oct 16, 2010 | 11:33 PM
aBLUEg35's Avatar
help!! bump
Old Oct 17, 2010 | 05:46 PM
aBLUEg35's Avatar
anyone else have any imput? im lookin for ideas of how the o2's heaters burned out....
Old Oct 18, 2010 | 07:42 AM
M302_Imola's Avatar
Just a shot in the dark but it could be because of your HFC's, although with as many people running HFC's you would think this would be a known problem if it is indeed the case.
Old Oct 18, 2010 | 08:58 AM
MHellmann's Avatar
Before you replace your O2 sensors, you should check them real quick, they usually don't fail all at once. O2 sensors are small voltage generators that work at around 600 degrees. Simply put them in a vise (gently) and warm them with a simple hand help propane torch.
With your volt meter connected you should see around .8 volts when they warm up, then remove the torch and the voltage should drop to near zero. Wire brush the flutes and clean out the slots.
A little more O2 info:
Enjoy…
These procedures are only for self powered conventional sensors.
Some very new cars are using a different style sensor that is powered. *Many* Oxygen sensors are replaced that are good to excellent. *Many* people don’t know how to test them. They routinely last 50,000 or more miles, and if the engine is in good shape, can last the life of the car.
What does the O2 sensor do?
It is the primary measurement device for the fuel control computer in your car to know if the engine is too rich or too lean. The O2 sensor is active anytime it is hot enough, but the computer only uses this information in the closed loop mode. Closed loop is the operating mode where all engine control sensors including the Oxygen sensor are used to get best fuel economy, lowest emissions, and good power
Should the O2 sensor be replaced when the sensor light comes on in your car?
Probably not, but you should test it to make sure it is alive and well. This assumes that the light you see is simply an emissions service reminder light and not a failure light. A reminder light is triggered by a mileage event (20-40,000 miles usually) or something like 2000 key start cycles. EGR dash lights usually fall into the reminder category. Consult your owners manual, auto repair manual, dealer, or repair shop for help on what your light means.
How do I know if my O2 sensor may be bad?
If your car has lost several miles per gallon of fuel economy and the usual tune up steps do not improve it. This *is not* a pointer to O2 failure, it just brings up the possibility. Vacuum leaks and ignition problems are common fuel economy destroyers. As mentioned by others, the on board computer may also set one of several failure “codes”. If the computer has issued a code pertaining to the O2 sensor, the sensor and it’s wiring should be tested. Usually when the sensor is bad, the engine will show some loss of power, and will not seem to respond quickly.
What will damage my O2 sensor?
Home or professional auto repairs that have used silicone gasket sealer that is not specifically labeled “Oxygen sensor safe”, “Sensor safe”, or something similar, if used in an area that is connected to the crankcase. This includes valve covers, oil pan, or nearly any other gasket or seal that controls engine oil. Leaded fuel will ruin the O2 sensor in a short time. If a car is running rich over a long period, the sensor may become plugged up or even destroyed. Just shorting out the sensor output wire will not usually hurt the sensor. This simply grounds the output voltage to zero. Once the wiring is repaired, the circuit operates normally. Undercoating, antifreeze or oil on the *outside* surface of the sensor can kill it. See how does an Oxygen sensor work.
Will testing the O2 sensor hurt it?
Almost always, the answer is no. You must be careful to not *apply* voltage to the sensor, but measuring it’s output voltage is not harmful. As noted by other posters, a cheap voltmeter will not be accurate, but will cause no damage. This is *not* true if you try to measure the resistance of the sensor. Resistance measurements send voltage into a circuit and check the amount returning.
How does an O2 sensor work?
An Oxygen sensor is a chemical generator. It is constantly making a comparison between the Oxygen inside the exhaust manifold and air outside the engine. If this comparison shows little or no Oxygen in the exhaust manifold, a voltage is generated. The output of the sensor is usually between 0 and 1.1 volts. All spark combustion engines need the proper air fuel ratio to operate correctly. For gasoline this is 14.7 parts of air to one part of fuel. When the engine has more fuel than needed, all available Oxygen is consumed in the cylinder and gasses leaving through the exhaust contain almost no Oxygen. This sends out a voltage greater than 0.45 volts. If the engine is running lean, all fuel is burned, and the extra Oxygen leaves the cylinder and flows into the exhaust. In this case, the sensor voltage goes lower than 0.45 volts. Usually the output range seen seen is 0.2 to 0.7 volts.
The sensor does not begin to generate it’s full output until it reaches about 600 degrees F. Prior to this time the sensor is not conductive. It is as if the circuit between the sensor and computer is not complete. The mid point is about 0.45 volts. This is neither rich nor lean. A fully warm O2 sensor *will not spend any time at 0.45 volts*. In many cars, the computer sends out a bias voltage of 0.45 through the O2 sensor wire. If the sensor is not warm, or if the circuit is not complete, the computer picks up a steady 0.45 volts. Since the computer knows this is an “illegal” value, it judges the sensor to not be ready. It remains in open loop operation, and uses all sensors except the O2 to determine fuel delivery. Any time an engine is operated in open loop, it runs somewhat rich and makes more exhaust emissions. This translates into lost power, poor fuel economy and air pollution.
The O2 sensor is constantly in a state of transition between high and low voltage. Manufacturers call this crossing of the 0.45 volt mark O2 cross counts. The higher the number of O2 cross counts, the better the sensor and other parts of the computer control system are working. It is important to remember that the O2 sensor is comparing the amount of Oxygen inside and outside the engine. If the outside of the sensor should become blocked, or coated with oil, sound insulation, undercoating or antifreeze, (among other things), this comparison is not possible.
How can I test my O2 sensor?
They can be tested both in the car and out. If you have a high impedance volt meter, the procedure is fairly simple. It will help you to have some background on the way the sensor does it’s job. Read how does an O2 sensor work first.
Testing O2 sensors that are installed
The engine must first be fully warm. If you have a defective thermostat, this test may not be possible due to a minimum temperature required for closed loop operation. Attach the positive lead of a high impedance DC voltmeter to the Oxygen sensor output wire. This wire should remain attached to the computer. You will have to back probe the connection or use a jumper wire to get access. The negative lead should be attached to a good clean ground on the engine block or accessory bracket. Cheap voltmeters will not give accurate results because they load down the circuit and absorb the voltage that they are attempting to measure. A acceptable value is 1,000,000 ohms/volt or more on the DC voltage. Most (if not all) digital voltmeters meet this need. Few (if any) non-powered analog (needle style) voltmeters do. Check the specs for your meter to find out. Set your meter to look for 1 volt DC. Many late model cars use a heated O2 sensor. These have either two or three wires instead of one. Heated sensors will have 12 volts on one lead, ground on the other, and the sensor signal on the third. If you have two or three wires, use a 15 or higher volt scale on the meter until you know which is the sensor output wire.
When you turn the key on, do not start the engine. You should see a change in voltage on the meter in most late model cars. If not, check your connections. Next, check your leads to make sure you won’t wrap up any wires in the belts, etc. then start the engine. You should run the engine above 2000 rpm for two minutes to warm the O2 sensor and try to get into closed loop. Closed loop operation is indicated by the sensor showing several cross counts per second. It may help to rev the engine between idle and about 3000 rpm several times. The computer recognizes the sensor as hot and active once there are several cross counts.
You are looking for voltage to go above and below 0.45 volts. If you see less than 0.2 and more than 0.7 volts and the value changes rapidly, you are through, your sensor is good. If not, is it steady high (> 0.45) near 0.45 or steady low.
Testing O2 sensors on the workbench.
Use a high impedance DC voltmeter as above. Clamp the sensor in a vice, or use a plier or vice-grip to hold it. Clamp your negative voltmeter lead to the case, and the positive to the output wire. Use a propane torch set to high and the inner blue flame tip to heat the fluted or perforated area of the sensor. You should see a DC voltage of at least 0.6 within 20 seconds. If not, most likely cause is open circuit internally or lead fouling. If OK so far, remove from flame. You should see a drop to under 0.1 volt within 4 seconds. If not likely silicone fouled. If still OK, heat for two full minutes and watch for drops in voltage. Sometimes, the internal connections will open up under heat. This is the same a loose wire and is a failure. If the sensor is OK at this point, and will switch from high to low quickly as you move the flame, the sensor is good. Bear in mind that good or bad is relative, with port fuel injection needing faster information than carbureted systems.
ANY O2 sensor that will generate 0.9 volts or more when heated, show 0.1 volts or less within one second of flame removal, AND pass the two minute heat test is good regardless of age. When replacing a sensor, don’t miss the opportunity to use the test above on the replacement. This will calibrate your evaluation skills and save you money in the future. There is almost always *no* benefit in replacing an oxygen sensor that will pass the test in the first line of this paragraph.
Old Oct 18, 2010 | 09:30 AM
Tim@Grubbs's Avatar
Let us know if you decide to grab some new ones. I'm sure we can help you out.
MHellmann's Avatar
Some helpful O2 info
An Oxygen sensor is a chemical generator. It is constantly making a comparison between the Oxygen inside the exhaust manifold and air outside the engine. If this comparison shows little or no Oxygen in the exhaust manifold, a voltage is generated. The output of the sensor is usually between 0 and 1.1 volts. All spark combustion engines need the proper air fuel ratio to operate correctly. For gasoline this is 14.7 parts of air to one part of fuel. When the engine has more fuel than needed, all available Oxygen is consumed in the cylinder and gasses leaving through the exhaust contain almost no Oxygen. This sends out a voltage greater than 0.45 volts. If the engine is running lean, all fuel is burned, and the extra Oxygen leaves the cylinder and flows into the exhaust. In this case, the sensor voltage goes lower than 0.45 volts. Usually the output range seen is 0.2 to 0.7 volts.
Old Oct 18, 2010 | 05:50 PM
aBLUEg35's Avatar
i was told it is the o2 heaters not the actual o2's. im wondering what could have caused them to fail.. the heat from the vortech? my EGT gauge hit 1500 but i checked into it and that seems to be where everyone else is.
Tim what do you guys carry? oem? im told these are the MOST durable
Old Oct 18, 2010 | 05:52 PM
aBLUEg35's Avatar
guys thanks for all the help! any other ideas?
