U1000 and U1001 SES???
Old Apr 24, 2011 | 03:48 PM
sirgeathan's Avatar
saw
swsadas
Old Apr 24, 2011 | 06:43 PM
timka86's Avatar
poor ground connections. common on the nissan altima's and maxima's. i believe theres a Tsb for this, you have to clean the ground on the left side dash support, the support itself is a ground and it's bolted to a PAINTED car frame member, you have to remove it and brush/scrape the paint and put the bracket back. i believe the TSB says to clean all the grounds, but i found that this particular bracket is the biggest culprit.
Old Apr 25, 2011 | 08:30 AM
sirgeathan's Avatar
swsadas
Old Apr 25, 2011 | 09:12 AM
show2nite's Avatar
The U1000 error code Also could happen whenever someone manipulate the ECU.
Old Apr 25, 2011 | 01:27 PM
sirgeathan's Avatar
swsadas
Old Apr 25, 2011 | 05:19 PM
sirgeathan's Avatar
swsadas
Old Apr 25, 2011 | 05:38 PM
timka86's Avatar
check for evidence of mice under hood
seen wires chewed up
Old Apr 25, 2011 | 06:23 PM
sirgeathan's Avatar
swsadas
Mry
Mar 3, 2023 01:03 AM
Vqalexisz
Oct 14, 2015 12:48 AM
vamarris
Sep 26, 2015 12:56 PM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
