Warning another NOOB!
The RACK for you
So bought the new A/C condenser.
Got tranny fluid.
I think I have ALL the bits for the initial run & drive...
Except a few connectors...
Then it's on to safety ( I know SISSY ).
Got a pass side air bag.
Some go fast sillycone coolant hoses.
Stock front rotors & pads.
and the HI PO hood prop & grommet
At the rate it going about 2 more weeks..
Need 1/8 of an inch on the top subframe rail, before the new sheetmetal gets put back on...
MAJOR PROP'S to Ritchie @ A&K Frame & alignment
25834 Springbrook Ave
Santa Clarita, CA 91350
(661) 259-3228
A TRUE old school craftsman !!!!!
Everything is inspected & triple checked and done 100%!
So there you have it...
Mike
Got tranny fluid.
(661) 259-3228
Mike
Progress report
The frame is now the correct length, the correct sub frame pieces are here & going on next week, I also now have the correct rear rims & tires. the suspension on the pass side is 100%. Delivered the battery, pass side fender, silicone hoses, squirter rez & fill neck. I have the pass side air bag now.
and all the connectors for items that got CRUSHED in the accident.
I'll have a day or so in repinning & testing sub systems.
I'm happy with the progress..
Last bits would be pass side interior door grab.
Front seat belts & repair of the dash pad ( or dash replacement ) .
Ok more progress
https://g35driver.com/forums/members...r-project.html
Today, delivered the hood,O rings for the A/C, more wiring harness...front bumper & energy absorber.
All the frame work is done, and now it's dry fitting time and it all looks great.....
The front rims are on the back and the back is on the front ( great! ).
So more news as it's available.
Mike
Mike
So it's 4th of July weekend and the shop is taking a long weekend.
BUT I was able to stop by....
We are here:
The front pass side loom and all connectors are repaired and looking factory!
I did have to point out what connectors when where, which is difficult since 1/2 the front end bits are all over the shop...
New arrivals on parts:
Scored a drivers side seat belt ( not blown ).
Scored a front license bracket.
Scored a new grille ( non stock ).
The new stock rotors & pads are in..
The power steering lines are going back in ( since 2 were crushed in the PO's accident ).
Optima battery is in & all blown fuses in that STUPID panel behind the battery are replaced.
Glass goes in next week.
Drivers side fender ( had a few dings from the crash ) are paint ready.
All the frame bits that were replaced, or adaptor's, brackets used on the pull are removed, painted factory color & finished to factory.
So next week....
Fenders, hood, radiator core support all go to final bolt up and finish alignment
Power steering finalized, Cooling system installed, Auto tranny lines fixed & system topped off. AC condensor High side switch installed and all lines resealed..
Start up and verify that tranny works ( it did for a bit, till most of the fluid bled out on my driveway!) verify mechanicals
Misc parts needed....
Need the resonator that goes below the air cleaner assy.
One of the top radiator twist locks is missing & one lower radiator grommet is missing.
Now I know why these cars usually are not brought back from the dead....
This is getting expensive!! BUT I know it will be great when done..
Happy 4th!
Mike
We are here:
So next week....
Happy 4th!
Mike
Don't buy the resonator but instead do this mod
https://g35driver.com/forums/engine-...-anti-56k.html
I saw that post earlier....
Right now I want to go back to 100% stock to have a good baseline....
THEN I'll start the mods....
Now Air bags, paint & bodywork is more important than a set of blingy rims!
( yeah I know..BORING! )
Mike
Mike
Less than 2 weeks to go....
Windshield in! ( and they broke the first one DOH! )
Adding magic fluid ( 5 qts of Nissan ATF ) and now the tranny actually functions.
All wiring in & tested..
Have to find more parts, inner fender skirts and such.....
First color goes on tuesday~!
There are some MINOR fitment issues but nothing major~
She fires right up....
We're SO CLOSE!
Mike
We're SO CLOSE!
Mike
Out of Paint
So left to go...
Pinstriping
Pass side front inner fender covers
Fit front grille better
Smog under hood stickers
Charge AC
Factory stereo ( just to get AC working )
Then belts, air bags Pass side interior door panel..
Clean & detail
Smog, Lights & brake inspection, VIN inspection...
THEN the fun stuff!
Mike
So left to go...
Pinstriping
Charge AC
Clean & detail
THEN the fun stuff!
Mike
It's HOME and beautiful~
Which means I've just started!
So I can't take tomorrow off BOOOO HISSSSSSSS
and I really can't drive it till smog, vin , light & brake inspection
But THIS chapter is done!
Mike
Mike
