Warning another NOOB!
Old Jan 19, 2012 | 12:35 AM
  #76
Frankieg35's Avatar
Any updates??
Old Feb 13, 2012 | 01:43 AM
  #77
jobad007's Avatar
hey what you pay for the car and and the parts and to put back in one piece
if you don't mine me asking
Old Oct 22, 2012 | 10:26 AM
  #78
vigman's Avatar
Ok so the car has been a dream...
1 issue, the 2nd fan for the radiator started getting intermittant ( and of course during the blazing hot So Cal summer ) other than that... perfect...
Well there is one more thing, I think I need a new seat track for the drivers seat.. it ***** a bit on full retract....
I just bought a 4 pot Wildwood caliper setup for the fronts and I have new rotors on order.. so that's next..
But this G has been just a dream.. well after all the nightmares...
Mike
Old Oct 22, 2012 | 01:02 PM
  #79
Lone Wolf's Avatar
Good job with the car man! A lot of people would have probably NEVER attempted to fix a car in that condition. Kudos to you.
Old Oct 26, 2012 | 05:20 PM
  #80
vigman's Avatar
And WILDWOOD IN
OOPS
Wilwood
Thanks to Theory_EK for the screamin deal....
had to do a bit of grinding & fitment... but now COOL!
The back story:
Perfect.. lots of clearance.. had to modify both calpiers ( grind 1/16th of the casting flashing off the lower mount ear.. it was hitting the knuckle ).. and the mounting kit was kinda stupid..
You need spacers between the bracket ( s ) to center the caliper to the rotor.. and the give you a bunch of washers..
It took 2 to space the caliper inboard ~ 3.X mm.
After fighting with that ~ 1 hr of dryfit.. remove .. test.. remove.. shim.. measure.. remove.. final adjustment.. etc
I used Brembo rotors 09 B530 10's, went for the cheapos till I knew it would all be GROOVY...
The only thing that's a bit weird is the routing for the AN lines..
To long to be a home run...
Way to short to follow the infiniti original path.. so I have em going round the strut... kinda ty wrapped ( loosly ) outta harms way...I will probably go with a different ( longer ) AN-3 kit to get a better route and tie off to the suspension better..
But they do do the trick....
I only wanted about 20% more stopping power.. and I got it and more..
Thanks
Mike
Old Nov 23, 2012 | 10:54 PM
  #81
vigman's Avatar
And update....
I didn't care for the stainless lines that came with the kit....
Got some 22" lines from Wilwood.... to route the lines " better "....
AND
The pads started to squeal....
So magic anti squeek.. re route the lines... make new brackets
Much better !
Mike
Old Nov 24, 2012 | 07:19 PM
  #82
VisualSeven's Avatar
holy **** i read everything and it was entertaining
I got a question tho how much did everything end up costing you? with a car and parts, was it worth it?
If you can't answer it, its fine just wondering what a front end collision can cost like
Old Nov 24, 2012 | 10:27 PM
  #83
vigman's Avatar
Suffice it to say it would have been cheaper to have found a complete one....
BUT I would have learned NOTHING.. and this way I built it the way I wanted it to be... and repaired all the PO's Oh by the ways....
It was a project car .. which means it's not a money thing
Old Nov 25, 2012 | 12:04 AM
  #84
oh alright, sounds good. Seems like you dedicated a **** ton of time into this too. Keep this updated it was entertaining reading all of it
Old Nov 25, 2012 | 10:55 PM
  #85
vigman's Avatar
And breaking news .. literally
The power seat track is starting to mis behave... only at the very back
As you approach full retract the left track seems to go back further ( 1/2 inch ) the the right...
This is probably due to Fat *** butt slide syndrom...
OR
A chunk of change stuck in the right track...
the good news... you can get nylon gears on e bay!
http://www.ebay.com/itm/271057072605...84.m1438.l2649
Old Nov 30, 2012 | 03:17 PM
  #86
Adro's Avatar
$580.00....
To tranfer title, tax, salvage fee, outta state car, to many
penguins tax, sky is blue tax, this came from a state with a low IQ so
you must have one too tax, OH wait and you have a drawl in your voice
20% tax.
New title search fee, hit the printer button twice surcharge, DMV
training to have that indifferent look. penalty..
I still need smog, brakes, lights inspection..
THEN DMV has to do a vin verification ARRGGHH
Mike
I lol'd at this
Nice G. I am wanting to do the same thing but now I'm too low on cash
tal1412
Nov 28, 2022 09:25 AM
crakke
Sep 1, 2015 04:23 PM
