Warning another NOOB!
Old Sep 8, 2011 | 10:53 PM
  #61
T4RUSAF's Avatar
for what?
Old Sep 8, 2011 | 11:24 PM
  #62
vigman's Avatar
read gas tank post...
BTW did you get your buttons?
MIke
Old Sep 8, 2011 | 11:26 PM
  #63
T4RUSAF's Avatar
yea man, thanks. Left an itrader post yesterday or so. So you forking out the 700 for a new gas tank or did you find one used?
Old Sep 8, 2011 | 11:31 PM
  #64
vigman's Avatar
The 700 was for LABOR to pull the tank....
Gonna have it welded.....
It's actually not a big deal ... gotta do a CO2 fogging of the tank pre welding...
No oxygen, no BOOM...
It's like a #10 hole ( 4-5 mm )
Mike
Old Sep 8, 2011 | 11:33 PM
  #65
T4RUSAF's Avatar
damn... looks like you got it under control. If you don't mind me asking, what did you pay for this thing? Did you get it at a steal? you can PM me, but its not that serious, more a curiousity. Just alot of work but that's probably because I'm getting old lol
Old Sep 8, 2011 | 11:35 PM
  #66
vigman's Avatar
Remember
Exhaust comes out, D/S out, E brake cables , rear X member cross brace, tank heat shield, rear seat, wiring & vapor, fuel lines.....
etc etc....about 8 hrs @ 85hr.. for in & out
Old Sep 9, 2011 | 01:43 AM
  #67
jenxin's Avatar
Hope no more problems show up! Best of luck man.
Old Sep 9, 2011 | 10:53 PM
  #68
vigman's Avatar
Thanks!
( It's a car, there's ALWAYS issues )
Mike
Old Sep 16, 2011 | 05:00 PM
  #69
vigman's Avatar
Car's back ! YEAH....
Full tank , no leaks
Plus oil change & 4 qt tranny flush again ( it was DIRTY ) but what can you expect after 89K without service?
and they touched up the alignment....
All good~
Mike
Old Sep 18, 2011 | 08:46 PM
  #70
vigman's Avatar
Mod of the day....
Stillen Z tube to go with the POP charger!
Up & coming...
New ( used ) 56mm Radiator
Tranny cooler
Aluminum underbody shield
BUT my 300ZX TT needs some luv...
So I will not be doing many hi $$ mods in the G for a bit...
( have to repaint the D/S side 1/4 panel )
Mike
Old Sep 30, 2011 | 11:44 PM
  #71
vigman's Avatar
Ok Murphy strikes again!
Coming home the other day.... I stopped at a light and a few whisps of smoke came out from under the car....got on the driveway... and sure enough I'm leaking....and it's getting on the pipes. There is also an oily film on the rear bumper...
So off to the stealership.... tranny rear seal & oil cooler...
I just said fix it....
I WANT MY CAR BACK!
Mike
Old Oct 2, 2011 | 11:46 AM
  #72
vigman's Avatar
That's done & I had them put in my aluminum lower splash shields in too!
Slowly but surely getting better every day....
and 19.28 MPG avg....
Mike
Old Oct 2, 2011 | 12:18 PM
  #73
fshields2's Avatar
Good luck bro! Seems like your headed in the right direction
Old Dec 16, 2011 | 11:34 PM
  #74
vigman's Avatar
Update:
New Koyo 36mm radiator IN
Tranny cooler ( with electric fan ) IN
New Nissan water pump IN
New Nissan stat IN
Samco red hoses IN
Mike
Old Dec 17, 2011 | 12:14 PM
  #75
Frankieg35's Avatar
I just read your whole thread.. it was entertaining.. lol u did a hell of a lot of work!! I'm glad to see its pretty much done.. post some pics.. lol
