Touchy AC
Hey guys, I've been having an issue with my AC recently. When i turn it on, sometimes it works and sometimes it doesnt. If it doesnt work and i leave it on, it sometimes comes on eventually at some random point. Any ideas o how i can fix this?
Could be the electronics within the controller. This is a known issue as long as you have ensured you have freon, no leaks and your system is 100% perfect. The Radio and AC controls go bad over time and you can swap out the unit for aftermarket or get it re-soldered.
http://www.ebay.com/itm/REPAIR-Infin...1a9b3c&vxp=mtr
Take it to a shop for a general AC checkup and let the professionals handle it. To check the level of refrigerant. You will have to remove all refrigerant and the machine will tell you how much it took out. Then you manually put back in the correct amount. Basic math will tell you how much was removed and how much was added to calculate the difference.
I would have a general AC check up to make sure all AC function perform correctly such as compressor, pressure switches, condenser, receiver drier and no leaks in the lines or system. Tell the shop the issue and let them know the AC/Radio head unit is known to go bad and will stop the AC for turning on/off or changing the settings.
Yes because aftermarket means you have to buy a dash kit which comes with a new controller. You can pickup an aftermarket dashkit with controller or OEM. I would recommend the OEM on if you plan to keep the car for a long time and want to sell it in OEM form.
This is a fan relay switch problem, I just had the same thing! Just look it up, you can actually buy the relay online or at auto shops for pretty cheap and just change them out trust me on this
I dont really know the part number but if you google 2006 g35 fan relay a bunch of info comes up and parts its a blue adapter plug with prongs like this:
http://www.partsgeek.com/catalog/2006/infiniti/g35/climate_control/blower_motor_relay.html
johnnyzee
V36 Brakes, Suspension, Wheels & Tires
332
Nov 1, 2018 05:08 PM
zillmc
Feb 16, 2008 11:09 AM
Jim123
Jan 14, 2008 03:16 PM
