How loud is the "howling" of a bad wheel bearing?
Old Aug 5, 2015 | 11:24 PM
ScraggleRock's Avatar
So, I have never experienced a bad bearing in any car I've ever owned. I've recently noticed this almost "white noise" coming from the rear of my car. It's almost sounds like how people describe a bad bearing in the G (meaning it kinda sounds like a "wind tunnel"). I feel like the sound has a bit of tremelo to it too, so to me it sounds like I have some pigeons cooing in my trunk.
However, the sound is fairly faint and my tires are getting close to being replaced. It's so faint in fact, that if I stop paying attention to it I can forget it's there. It could be tire noise, but Im just wondering how loud a busted bearing is..?
Old Aug 5, 2015 | 11:25 PM
Hotdawwgman's Avatar
My. Car does the same thing... I am pretty sure it's my bald rear tires
Old Aug 5, 2015 | 11:27 PM
Yeah, my tread is pretty close to being done. They aren't bald tho; maybe it's just the tires.
Old Aug 6, 2015 | 07:07 AM
VenomGT9's Avatar
I wouldn't say that's the bearing. One of my fronts went out last year and all I heard was this faint, yet annoying ticking every time I turned the wheel. Your case sounds more like a tire issue
Old Aug 6, 2015 | 12:48 PM
Gonna change em this week. And we'll see.
Old Aug 9, 2015 | 08:04 AM
Urbanengineer's Avatar
Swap the tires side to side or run the spare there. Don't just throw parts at it. Make sure it is the issue.
Old Aug 9, 2015 | 03:17 PM
I'm not running the tires backward. I've made that mistake in my younger days. Besides, I already have the two tires sitting in my house, cuz I bought 4 but only the front 2 were urgent (shocks were blown, so heavy cupping).
Old Aug 10, 2015 | 04:29 PM
coffeysm's Avatar
Probably your tires. I heard a faint whistling or scraping noise as well from my passenger rear. Brought it to a mechanic also, because I thought I was going crazy and it ended up being the tires pretty much. I had a sticking caliper also, but it was the tires causing the most problem.
I had bearing go out on the same tire as well about two yaers ago and it wasn't faint at all!
Old Aug 10, 2015 | 04:52 PM
Yeah, I assumed it would be highly obvious if it were a bearing, but like I said, I have never actually heard it. Changing the tires tomorrow tho..or maybe today if I stop being lazy..
Old Aug 11, 2015 | 04:04 PM
You aren't driving fast! Just swap em quick and take off slow to 35mph. It will be obvious.
Old Aug 11, 2015 | 05:38 PM
Nah, I'm good. You should never run a radial tire backward from its originally installed direction. Some people claim this is a thing from the past when tires were made differently, but I have personal experience as to why this should never be done.
Old Aug 11, 2015 | 09:00 PM
True, but you could find another wheel and run the spare and see if your issue persists. .
Old Aug 11, 2015 | 10:16 PM
Well, I just changed my tires and its gone. Haha
Cajuncowboy
Jun 21, 2021 09:47 AM
rezendvous420
May 31, 2020 01:26 PM
Xfactor
Dec 1, 2019 12:52 PM
wuppiedog
Aug 7, 2015 11:16 AM
itschuckster
Jul 25, 2015 08:07 AM
