Trunk will not open
Old Nov 18, 2015 | 08:34 PM
MidNightG's Avatar
Trunk will not open
Won't open from fob or the interior button!??!?? Car has been driven multiple times since first noticed. Anyone have an idea? Is there a fuse to check for this issue?
Thanks
-dfelz
Old Nov 18, 2015 | 10:14 PM
hurleyguys's Avatar
there is a switch in/next to your glove box that makes it so the trunk wont open. flip the switch and try again.
Old Nov 19, 2015 | 09:40 AM
MidNightG's Avatar
Thanks hurleyguys,
Reset the glove box button twice and still no luck.
Any other ideas!???
Old Nov 19, 2015 | 09:43 AM
andrewvk's Avatar
yes, you have some broken wires in your trunk lid. you need to manually pop the trunk. pull back the grommet and re solder the wires. takes about 30 min.
this is a very common issue and there is tons of info on the subject.
Old Nov 19, 2015 | 01:12 PM
MidNightG's Avatar
Thanks andrewvk!!
Any chance you can provide a link to a thread on here with good instructions on doing so??
Old Nov 19, 2015 | 05:34 PM
Urbanengineer's Avatar
Look for the sticky, this is common. Or! You can do what I did when I was lazy and under warranty and have the dealer replace the rear harness... For $1300 (covered in my case *whew*!).
Old Nov 26, 2015 | 04:13 PM
medoug's Avatar
Read this thread (especially the last post that I added) to correctly diagnose and fix your problem:
https://g35driver.com/forums/general...ggestions.html
A search of the forums "trunk release" would have quickly found this for you.
Old Nov 26, 2015 | 11:58 PM
MidNightG's Avatar
Thank you medoug!
Old Dec 11, 2015 | 01:42 AM
MidNightG's Avatar
Originally Posted by MidNightG
Thank you medoug!
Thanks for link, was able to finally get this fixed as well! One wire was sheared straight through! Made a small jumper cable, soldered it on and heat shrinked it, has been working the past week just fine
Old Dec 11, 2015 | 08:20 AM
andrewvk's Avatar
glad you got it fixed.
Old Dec 11, 2015 | 10:21 AM
MidNightG's Avatar
Me too!!! Was so inconvenient!!
trini35
Jul 5, 2025 04:13 PM
AJC128
V36 Audio, Video & Electronics
12
Feb 14, 2022 08:10 PM
JOKER
Interior
83
Nov 18, 2017 10:55 AM
deathdoakill
Nov 12, 2015 05:50 PM
jake619
Nov 11, 2015 01:38 PM
