Oil Seeping out of spark plug well AFTER replacing valve covers.
04 G35 Coupe AT with 170XXX miles. Oil was leaking from passenger side valve cover towards the front of the engine out of valve cover gasket and front most spark plug well before replacing and now the same thing is happening again after replacing valve covers (eBay valve covers and Felpro valve cover gaskets) but towards the rearmost spark plug well. No oil coming out of the actual valve cover gasket. I’m thinking maybe this is happening because the valve covers were from eBay, but could it be more deep than that? Any advice appreciated.
https://conceptzperformance.com/nissan-infiniti-nissan-oem-valve-cover-set-w-gaskets-vq35de-nissan-350z-infiniti-g35-m35-fx35-13264-am600-10_p_28857.php. Put a little gasket sealer on the bottom of the spark plug seals as insurance. Use brake parts cleaner to remove any residual oil on the cylinder head mating surfaces to ensure good sealing. Apply sealer per the service manual on the rest of the valve cover. A little goes a long way due to compression when you tighten the cover. I prefer Permatex black gasket maker.
Originally Posted by Pbfoot
https://conceptzperformance.com/nissan-infiniti-nissan-oem-valve-cover-set-w-gaskets-vq35de-nissan-350z-infiniti-g35-m35-fx35-13264-am600-10_p_28857.php. Put a little gasket sealer on the bottom of the spark plug seals as insurance. Use brake parts cleaner to remove any residual oil on the cylinder head matting surfaces to ensure good sealing. Apply sealer per the service manual on the rest of the valve cover. A little goes a long way due to compression when you tighten the cover. I prefer Permatex black gasket maker.
onthe3rdday
183
Nov 7, 2021 07:59 AM
v36nspec
Jul 27, 2020 12:47 AM
SnglTrboG35
Jan 29, 2011 03:04 PM
