Oil everywhere please help
Old Jan 8, 2022 | 02:40 PM
Nixon23's Avatar
I got on it on the interstate and my car started smoking bad and when I got home there was oil in the driver side wheel and all underneath the car. What could have happened? Ive attached 3 pictures
Old Jan 8, 2022 | 03:37 PM
Scorpi0's Avatar
Could be a busted hose. Could be a broken oil pan. Could be your drain plug came loose.
Look in there and see where its comin from.
Old Jan 8, 2022 | 05:03 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Yep, lots of things it COULD be. Get the car up on jackstands and find out where it's leaking. Fortunately it should be pretty obvious but it's probably not even be engine oil since it looks pretty PINK in that picture, probably transmission fluid.
Old Jan 8, 2022 | 11:36 PM
Nixon23's Avatar
I went out to check the oil and noticed the dipstick wasn’t even inserted. Do you think that had anything to do with it?
Old Jan 8, 2022 | 11:42 PM
cleric670's Avatar
BANNED!!!
Possibly, but I still think it's tranny fluid covering the bottom of your car.
Old Jan 8, 2022 | 11:56 PM
Nixon23's Avatar
I’ll have it checked out by my mechanic considering I don’t know much about how to fix cars but I will check the fluid in that tomorrow. I’ll keep ya updated and I appreciate you replying back!
Old Jan 9, 2022 | 10:03 AM
cleric670's Avatar
BANNED!!!
With that much fluid it should be easy to find the leak because it will probably be dripping out a steady stream of fluid.
Old Jan 12, 2022 | 03:29 PM
MikeG35Coupe's Avatar
20 Year Member
One owner 2004 G35 Coupe 6MT
Any votes for a crankcase pressure issue blowing the dipstick (and some oil) out? I don't -think- it's ATF; I do see some pink-ish in the pictures but I think it's the lighting.
Old Jan 14, 2022 | 07:35 PM
cleric670's Avatar
BANNED!!!
It would have to be a completely cracked chunk of a piston ring to push that much oil out of the dipstick, the thought did cross my mind but you would have a dead cylinder in minutes and know something else was going on.
Old Jan 21, 2022 | 07:18 PM
20 Year Member
I wonder how the OP made out.
Skexay
Nov 7, 2020 03:19 PM
Xx AzN xX
11
Feb 22, 2012 07:54 PM
B_Williams
Jun 14, 2011 12:55 PM
rpm06g35
SFL G CLUB
Sep 12, 2008 10:32 PM
eldy
Southern California
Sep 9, 2004 04:24 AM
