Shield for Injen or other intakes??
Old Feb 19, 2004 | 03:25 PM
XCELR8's Avatar
Is there a shield available that partially covers the filter on the Injen intake that will help deflect debris/water? I have seen some of the intake systems with this add on around the filter, but dont see it on Injens website. Its either polished or chromed. I'm aware of the foam bypass valve and dont want that.
"Don't sweat the petty, Pet the sweaty"
2003 BLK/BLK 6-spd Injen clear corners
Old Feb 19, 2004 | 03:30 PM
XCELR8's Avatar
Re: Shield for Injen or other intakes??
The part circled in red. Where do you get that??
2003 BLK/BLK 6-spd Injen clear corners <P ID="edit"><FONT class="small"><EM>Edited by XCELR8 on 02/19/04 12:31 PM.</EM></FONT></P>
Old Feb 19, 2004 | 07:26 PM
Shader7's Avatar
Why don't you want the bypass? My vacuum measurements show the Nismo bypass is completely inactive (no vacuum change) at any rpm or speed (no testing above 105mph) unless a large section of the filter is covered. Clearly, it's not taking air from the bypass unless it has to; the path of least resistance is overwhelmingly through the normal filter.
Black/Willow 03.5 6MT, Premium, Navi, Aero, SAT
350Z Nismo CAI
Old Feb 20, 2004 | 01:47 AM
TooFastSGG35's Avatar
Those filters will clog up quick with salt if you are form the north. That might help some.
Old Feb 20, 2004 | 11:29 AM
XCELR8's Avatar
Can I buy the Nismo bypass seperatly and install it on the Injen intake? Where can I get just the bypass? If its not that big of a difference, I would rather have the protection against water.
I am from Northern Indiana. Salt capital of the country. Would probably take the Injen off in the winter anyways.
Old Feb 20, 2004 | 03:03 PM
pioneerdat's Avatar
That part that you circled is the Injen heatshield. You can get it here: http://www.ultrarev.com/ecart/shopexd.asp?id=9817
Old Feb 20, 2004 | 03:08 PM
XCELR8's Avatar
Sweet! Thanks :-)
Old Feb 21, 2004 | 02:28 PM
Shader7's Avatar
X, I think someone on the forum put an AEM bypass on the Injen intake, but I'm not certain. Maybe search it or start a new thread.
350Z Nismo CAI
Picture Share
Feb 4, 2018 12:41 PM
Video Share
Jan 31, 2017 04:00 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
vamarris
Sep 26, 2015 12:56 PM
