just installed ztube + POP charger v. heat shield question
Old Oct 10, 2008 | 01:11 PM
uf20wop's Avatar
it seems like the heat shield was designed for use with the g35 tube because the edge of the filter kind of rubs on the edge trim stuff, probably due to the fact the z-tube is shorter or something
does anyone else have this problem? if so, did you leave it as is or remove the heat shield?
but other than that, my car sounds bad *** now, i love it
Old Oct 10, 2008 | 04:21 PM
RAF702's Avatar
I just installed mine. Stillen z-tube and JWT popcharger. And had no fitment issues or anything. Only thing confused me was how to clamp the bottom part of the heatshield to the car.
And the car sounds amazing, around 3k you can hear a whistle. And after 5k the motor sceams. And the car feels much more responsive and smoother then before. I'm exciting to add more parts later on too!
Im glad you like the popcharger as much as I do!!
Old Oct 10, 2008 | 10:52 PM
idiosyncratic's Avatar
Yeah, I just put one in and the back inside edge of the filter sits on the heat shield, plus the bottom kinda sits on the heat shield too. Not sure if I installed it wrong, but I can't really seem to get it off the heatshield even after messing with the brackets.
Old Oct 11, 2008 | 08:28 AM
uf20wop's Avatar
do you have any pics of your setup with the stillen z tube?
uf20wop's Avatar
yep same here, i got it the best i could, but i still think something's weird about it
Old Oct 11, 2008 | 03:30 PM
deuce818's Avatar
does it cause any problems?
Old Oct 11, 2008 | 03:33 PM
Skaterbasist's Avatar
Retired SuperMod
The Pop-Charger's heat shield is useless.
Old Oct 11, 2008 | 04:47 PM
RAF702's Avatar
Ill try and take some pictures later when I get home or tomorrow when theres light.
Old Oct 12, 2008 | 02:59 PM
uf20wop's Avatar
it does kind of seem like it
Old Oct 12, 2008 | 03:24 PM
uf20wop's Avatar
awesome man thanks
Old Oct 14, 2008 | 09:27 PM
uf20wop's Avatar
bump
Picture Share
Feb 4, 2018 12:41 PM
Oregon13
Audio/Video/Electronics
Mar 1, 2016 12:06 AM
vamarris
Sep 26, 2015 12:56 PM
AuAltima3.5
Sep 13, 2015 11:48 AM
