Plenum Spacer
Old Dec 10, 2008 | 11:13 PM
Penguin11's Avatar
Plenum Spacer
im thinking about getting a motordyne 5/16 plenum spacer, i wanted to know is it really necessary for me to get the iso thermal 5/16? I live In the lower part of Texas btw.
Also with the upgrade iso thermal do i have to take off the lower plenum to put that gasket in?
Thanks in advance
Old Dec 10, 2008 | 11:52 PM
Hydrazine's Avatar
Thanks in advance
Its not necessary to do the Iso Thermal but your plenum will run a lot cooler with it.
And yes, you would have to take the lower plenum off to install the Aramid gasket.
If you don't feel comfortable with that extra step, don't do it. You can still use the Basic spacer and get the results shown in the dyno plots.
Installation of the basic spacer is really easy. Just open up the plenum like a clam shell, slide the spacer in and bolt it back down. That's pretty much it.
Old Dec 11, 2008 | 12:11 AM
Penguin11's Avatar
i just think the lower plenum is alot harder to take off and dont see it as being worth all the trouble
Old Dec 11, 2008 | 12:38 AM
EL-EE-ES's Avatar
i thought that the upper was more of a pain with the hoses, the lower was very easy
Old Dec 11, 2008 | 09:32 AM
byte_me77's Avatar
this will give you a good idea on how to do it.
http://www.infinitihelp.com/diy/gcou...er_install.htm
Old Dec 11, 2008 | 09:35 AM
Yv12345vY's Avatar
I definitely agree with this statement. Once the hoses came off and the upper plenum came out the aramid gasket was an extra 5 minutes of install time. I spent more time making sure everything was clean than on the actual installation.
Old Feb 20, 2009 | 02:57 AM
Eva G's Avatar
would I need iso thermal living in washington state? it rains a lot and occasionally snows here..
Old Feb 20, 2009 | 09:21 AM
Hydrazine's Avatar
Its not necessary but it is preferable.
Old Feb 20, 2009 | 02:01 PM
Eva G's Avatar
ok thanks a lot!
Old Feb 20, 2009 | 02:08 PM
Seymore's Avatar
I'd recommend Copper ISO for all personally.
I suppose I move more than most, but I never know where I might live 5 years from now. With the Copper ISO, you install it and never worry again, regardless of whether you move or not, or sell the car to someone that lives in, or may some day move to, a colder climate.
Old Feb 20, 2009 | 05:53 PM
bluemax189's Avatar
i got my iso 5/16 coming tomorrow via fedex. take the extra time and the slight extra cost for some lower intake temps. keep that peek power longer and avoid the heat soak.
Old Feb 22, 2009 | 04:12 AM
twalls's Avatar
CLUB MODERATOR
what would you say on 5/16 vs the 1/2? What's really the difference other than 2 hp? the sound? Do you not get the deep growl w/ the 5/16?
Old Feb 22, 2009 | 07:26 PM
bluemax189's Avatar
just installed popcharger, 5/16th iso kit and non rev lower today and boy what a difference, especially in the higher rpms. as for 5/16 vs 1/2, the dynos show a higher peak hp for the 1/2, but more usable power with the 5/16.
Old Feb 22, 2009 | 08:03 PM
Hydrazine's Avatar
^+1
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
prinny
Nov 22, 2015 11:07 PM
w4kj4k
Oct 2, 2015 07:57 PM
thechitoguy
Oct 1, 2015 05:25 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
