kinetix v+/ MD5/16 spacer combo ..
Old Jan 16, 2009 | 12:17 AM
g_boy's Avatar
i was just wondering if there is any gain if i add kinetix v+/ MD5/16 spacer into my car.
Old Jan 16, 2009 | 01:36 AM
Tollboothwilley's Avatar
That would be a overall 5/8" increase in size
Many people have 5/8" spacers, i do
They will be better as long as you have good exhaust.
Realistically, unless you have the spacer for really cheap, I'd just stick with the plenum.
Old Jan 16, 2009 | 02:38 AM
TXMAG's Avatar
A very slight gain will be had by using both instead of one or the other. Realistically though, it would be so little you could probably make your car go faster by going on a diet and losing 20 pounds.
From what I've seen 1/4" to 5/16" spacer is really all you need. You will get a bit more HP as you continue to increase the size, but it's an asymptotic curve.
The ratio of HP gained : increased size after 5/16" is pretty insignificant.
All of this is taking into account you are NA. If you go FI, maybe bigger is better. I don't know.
Old Jan 16, 2009 | 03:26 AM
TurTLe*'s Avatar
the kinetix design the plenum with a 5/16 spacer already in place.
its not like you can stack 2 mods together and expect double the performance. That comes back to ricer math. By doing this like what others have said you turn that 5/16 into 5/8 spacer instead.
just run which ever one you have and not get the other one because it would be a waste of money.
Old Jan 16, 2009 | 04:18 AM
TXMAG's Avatar
I forgot to add that you might run into fitment issues as well if you tried to stack those two.
Old Jan 16, 2009 | 05:34 PM
g_boy's Avatar
thanks alot guys.i just cancel my order.
Old Jan 16, 2009 | 05:57 PM
ttrank's Avatar
Grocery getter
This question has been asked many times before...
Old Jan 16, 2009 | 06:47 PM
Hydrazine's Avatar
+1 Spacers and plenums are not compatible with each other.
Also, after a point, increasing plenum internal volume begins to compromise TQ.
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
w4kj4k
Oct 2, 2015 07:57 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
