what can i do to my car to increase speed?
Old Oct 25, 2009 | 11:38 PM
infinitayyy13's Avatar
i drive a 2007 g35 coupe, its automatic, and i really wanna do some stuff to it in order to increase the horsepower. can anyone tell me the best things i can do? i know about the cold air intake but what about other stuff?
Old Oct 25, 2009 | 11:44 PM
dofu's Avatar
20 Year Member
Do you want acceleration or top end? Get an ECU reflash like the Osiris. Dyno tune it now or wait until you have all the bolt ons you want and then tune it. Either way, your car will be making more power than without the reflash.
Locksmith's Avatar
First thing is you should do a search
But honestly if you want to make power you need to go FORCED INDUCTION! When you add on N/A mods it barely does anything for the VQ motor, save up and get a nice turbo kit or a supercharger for your G35 and you'll be much happier. I'm currently still saving up for my turbo kit, hopefully by next winter that'll be my project
O HELLA OEM's Avatar
Motordyne spacer
if u really want more hp
u must go fi
Old Oct 26, 2009 | 01:55 AM
pfarmer's Avatar
First thing to do is analyze your driving habits, rpm, load, mph, and then do research on the various components that will give you the bang for the buck in the areas you want more power. For example various cold air intakes can be great for the track and maybe a negative for the street. The same goes for various exhaust systems. You need to match the mod to your driving habits not just the raw number claims you may see.
A mod may give you 10 hp but may do so at 5000 rpm and give you less hp than stock where you drive the most.
In the old days often the quick answer was if you want more low end power you change your rear end ratio, if you want more high end power you change your rear end ratio. If you wanted it in both places you tossed out the rear seat and spare tire.
Old Oct 26, 2009 | 07:00 AM
dofu's Avatar
20 Year Member
Originally Posted by pfarmer
First thing to do is analyze your driving habits, rpm, load, mph...
True, learning your car and how to push it to it's limits helps a lot here. If you don't know how to drive your car, then no mods will help make it much faster than it already is.
Old Oct 26, 2009 | 12:23 PM
eurodre's Avatar
hands down best mod for the g, is a search
Old Oct 26, 2009 | 02:58 PM
pfarmer's Avatar
The point was not to learn to drive your car, it was to learn exactly how you drive it, what part of the rpm range you are normally in, etc. and then to pick your mods accordingly.
rezendvous420
May 31, 2020 01:26 PM
Frostbite91
Jul 27, 2015 05:25 AM
rping
Jul 26, 2015 09:53 PM
multimut
Canada
Jul 26, 2015 08:43 PM
vstypicals
Jul 20, 2015 10:55 PM
