Advanced Resonance Tuning (ART Pipes)
Old Apr 6, 2012 | 01:57 AM
  #1006
DrkBLuG35Sdn's Avatar
Tony, any sound clips of a TDX 2 without ART pipes? Looking to purchase just the "catback" version.Effing CA emmissions!
Thanks!
Old Apr 6, 2012 | 04:58 PM
  #1007
MaDMaXX's Avatar
I believe there are some on my350z - The sound is pretty much the same, but isn't as loud.
Old Apr 6, 2012 | 06:43 PM
  #1008
Jairen's Avatar
Tony, please excuse me for not reading the entire thread, but I'm seeing some issues with the V1's cracking. Are the V1's still under warranty? If not, discounts to replace the cracked pipes?
Old Apr 6, 2012 | 10:58 PM
  #1009
Hydrazine's Avatar
Hi Jarien,
The ART pipes come with a 2 year warranty. Just send us an email with your contact and purchase information.
Old Apr 7, 2012 | 08:58 PM
  #1010
Tollboothwilley's Avatar
Originally Posted by Hydrazine
No but many times a power mod is actually more efficient. I even measured a 2%-3% increase in fuel efficiency in ART pipe development.
Another thing that often happens is people will use the extra power provided by a modification which will use more gas in the process.
Also, one thing you can do is dyno test to see where your A/F ratio is. If you find it is running rich its easy to fix with a tune.
No, i have done plenty of mods. The only change in mine recently was the subtraction of HFC for ART pipes. Other mods have shown increases in efficiency especially w/ a tune. My highway MPG dropped from 25 to 22 on the same trips i travel regularly (400 miles one way)
The decrease in fuel efficiency is related to the long term fuel tables and is evidenced by Uprev Cipher data logs on primary vs secondary O2 sensors.
Old Apr 8, 2012 | 12:51 AM
  #1011
MaDMaXX's Avatar
Have you recently reset your fuel learning?
I didn't see this change at all with my fitting of the ART's. It's quite possible that something else isn't quite right for you?
I did reset my fuel learning and i also had to relearn the idle air control.
Old Apr 8, 2012 | 08:37 AM
  #1012
youngG's Avatar
Will they be a version to fit x
Old Apr 8, 2012 | 09:31 AM
  #1013
Hydrazine's Avatar
The ART pipes do not cause a decrease in fuel efficiency. It seems there may be a air leak somewhere in the system. Air leaks can actually let air in the exhaust flow during the scavenge phase of the exhaust pulse. When air gets in, the A/F sensor reads excess oxygen in the system and thinks its running lean so it adds in more fuel to compensate, but adding more fuel to an already properly tuned system means its now running rich.
Check for a leak near the inlet flange.
Old Apr 8, 2012 | 09:34 AM
  #1014
Hydrazine's Avatar
I would like to but I will need access to one on a lift. The problem is nobody drives X's in So Cal.
Old Apr 8, 2012 | 09:41 AM
  #1015
Shanes_G's Avatar
tony, i<3 you.
Old Apr 9, 2012 | 11:17 AM
  #1016
There is no leak.
http://my350z.com/forum/tuning/55203...and-input.html
Old Apr 9, 2012 | 11:42 AM
  #1017
Hydrazine's Avatar
Try removing the steel wool inside the O2 sensor socket and let me know what you find. It may be what you need.
A short piece of heavy steel wire with a hook shape bent at the end of it can be used to pull the steel wool out.
Old Apr 9, 2012 | 12:58 PM
  #1018
ryanm8's Avatar
I never noticed any decrease in fuel efficiency with ART pipes, and I always monitor how many miles I get when I fill up. It's always around 20mpg.
Old Apr 9, 2012 | 01:01 PM
  #1019
It not typical driving - its only during longer trips (HWY) that it is noticeable.
Old Apr 9, 2012 | 01:02 PM
  #1020
ryanm8's Avatar
Ah, OK. I don't make many long trips over 30 miles or so, so I'm out on that one then
