Dynoing out the myth of Intake mods: The Results
The VQ engines do NOT respond well to Intakes...
The V8 muscle cars will easily give you 10-15hp increase from an intake...
Do more research before making such a general statement...
But in general, for V8s, all respond greatly to mods...specially since the stock intake is so restrictive on such a big engine...
Intake mods really depend on the car. Some intakes like the VQ are already 100% efficient from the factory. It also depends on power levels. Once you go FI even the VQ airbox becomes a bottleneck.
I have yet to see any conclusive evidence or test of an intake giving more than a few HP, which is more likely dyno or temp variances. If you have it, please post it and I will admit I was wrong. But chances are, if it's out there, I would've seen it by now. I'll say it again. Without significant breathing mods, ie. cam, larger valves, added displacement, etc. an intake is a waste. The stock intake will supply all the engine needs without those mods. Not to mention the added dust particles and heat the engine sees with most intakes. Again, please post evidence to prove me wrong.
And about the cavalier comment, my experience is mostly with stroked and cammed v8s, not something that comes out of a cavalier, although the power to weight would be awfully nice
again, 110% false, sounds like you are the one needing to do more research. No offense, just hate bad info on this type of thing. Again, post conclusive evidence and I'll admit I'm wrong. There is even a test showing oiled gauze filters letting more dust into an engine, another reason to leave it stock, I'll try to find that filter test
Post dynos please, I call bs. Again, no offense.
Does the VQ benefit from intake mods (without tuning) ??? No. Just like you said and this test confirmed.
Dose an LS1? Yes, absolutely, almost every single time.
You want proof? Go buy this: http://isbnlib.com/isbn/193249488X/H...V-8s-SA-Design
I thumbed through it at a summit store in GA, and it was chock full of in-depth dyno results on every single mod, and even had a section on cheap LS1 mods.
The cheap mods section specifically listed changing the intake box as one of the best, easiest ways of gaining 10-15 hp and backed it up with dyno tests.
And that's an independent test, not some company like SLP or K&N trying to push a product with tweaked dyno charts.
Just because something is true for a Japanese DOHC V6 in a Japanese designed car, does NOT mean it holds true for an American pushrod V8 in an American designed car!
I'm sorry if I come off a little rough, but you're the one acting like a know-it-all, when in reality you're spouting off incorrect information.
I'm not gonna buy the book, post something people can read without spending money. And I will not resort to name calling, unlike you sir. Either way, most of my experience is with earlier small blocks. Even if you did get 10hp, you're still letting in more crap into the chamber. Anyway, this is off topic so if you find something worth my time to read, send me a pm. Great test OP!
^Ok, then... don't buy it.
Do what I did and get out from behind your keyboard, go to a bookstore or a summit store, and thumb through it.
Or just do some research, there's plenty of proof on f-body sites that intake mods DO yield horsepower.
Some of the mods have nothing to do with the filter either.
GM puts baffles in the stock airbox lid (God knows why
) so you can actually increase flow and gain power simply by modding the factory air box and even keeping the oem filter.
Why would you be commenting on the LS1, and then defending your erroneous comments, if your experience is on earlier small blocks (which are in themselves entirely dissimilar to the LS1 anyway) ???
And now, suddenly, your going to remark that all of this is off-topic? Despite the fact that you're the one that brought up the LS1, therefore starting the OT discussion in the first place! Really???
) so you can actually increase flow and gain power simply by modding the factory air box and even keeping the oem filter.Why would you be commenting on the LS1, and then defending your erroneous comments, if your experience is on earlier small blocks (which are in themselves entirely dissimilar to the LS1 anyway) ???
Tell you what... YOU show me evidence that it doesn't increase power on an LS1. Post conclusive evidence that it doesn't work and I'll admit I'm wrong
