PPE Engineering LongTube Headers
#211
#213
#215
#216
if im in the 11s with a 150 shot, torque converter, and cutout at 4500ft elevation, i will be more than happy. id say you should be 11s pretty easy without having your floormat issue, lol
#217
I moved to Socal added some mods went to LACR hoping 13's my car was running 15's in 5k+ elevation which to them was fast. That was my 1st time learning the effects of elevation/DA I thought something was wrong with my car at first.
Now I'm back on the east coast running low 13's @ or below sea level.
#218
#220
How would those connect to your stock radiator if you still have it? Connect the trans cooler the same way hopefully that will answer your question. I'm not sure which one at the moment.
EDIT
just realized you are putting it in tandem with your radiator which I'm sure is not stock anymore so does it matter on which end it goes? The fluid will get cooled before or after the radiator.
EDIT
#221
#222
