Difference between test pipes and straight pipes
Old Dec 10, 2011 | 01:29 AM
saason.Ez's Avatar
i never found out the difference between the two... i see people say they have a catback exhaust with test pipes.. and straight piped. Can someone clear this up for me ? thanks
Old Dec 10, 2011 | 01:49 AM
ShanesG's Avatar
Test pipe= straigh pipe essentially. Just some Test pipes have resonators
Old Dec 10, 2011 | 02:38 AM
saason.Ez's Avatar
Thank you ShanesG
So does that mean you can get unresonated test pipes
and if i want to do that for my G, should i get Aftermarket test pipes without resonators or just modify my existing pipes? Thanks again
Old Dec 10, 2011 | 02:51 AM
CandlestickPark's Avatar
ill Sedan
Test Pipes are either resonated or non-resonated. No you can't just modify your existing OEM cats. I recommend resonated TPs otherwise you'll very likely have a ton of rasp (amount depends on the rest of your exhaust setup). Also I would suggesting looking into Motordyne ART pipes, they over better performance than Test Pipes.
Old Dec 10, 2011 | 02:57 AM
saason.Ez's Avatar
okay well I'm running Nismo CAI, Motodrome plenium spacer, Stillen headers and High flows, Stillen Catback, will the Motordyne ART pipes help with a lower, but considerably louder sound... also considering changing Y pipe and mid pipe any suggestions there.... Thanks for all the help guys !
Old Dec 10, 2011 | 09:28 AM
Hydrazine's Avatar
Quieter at low throttle positions and louder at high throttle positions.
And yes, it clearly has a deeper tone to it.
Old Dec 20, 2011 | 06:07 PM
re-crue13's Avatar
OB '04 Coupe Premium w/Performance Wheel & Tire
I always thought of test pipes as Marcus described them, either resonated or non resonated. Straight pipes to me, means removing every resonator/muffler from your exhaust system. It's just a crappy and disgustingly ugly exhaust sound with tons of rasp and usually a significant loss of power.
Old Dec 20, 2011 | 07:26 PM
butkiss1's Avatar
Stillen headers and High flows, Stillen Catback .......................Those three items = Rasp ,Rasp & more Rasp, so much rasp that you'll need a "Rasperater"....LOL
The fix is easy though , Trust me bro ! I know cause I run the same set up with the exception of the Art pipes....but I used to run ur same exact set up and I got rid o all the rasp , Ur siht will be deep!
R u a coupe or sedan ?
Old Dec 21, 2011 | 11:23 AM
saason.Ez's Avatar
LMAO thanks bro yea i know its a coupe ... so whats your current setup ?
Old Dec 21, 2011 | 11:44 AM
butkiss1's Avatar
I'm literally in my RV going out of town. call me and I can give you the information verbally or you have to wait for a while until I can get back to my laptop in about a week and a half and post the links for you my name is bill in my phone numbers 8187306013
Old Dec 21, 2011 | 12:20 PM
broke_as_ajoke's Avatar
just too funny
Old Dec 21, 2011 | 01:31 PM
butkiss1's Avatar
Ok the short and sweet.
kill the two Stillen resonators replace with Magna flow resonated x pipipe. Kill Stillen mufflers replace with Magna flow. At the beach With the baby. Ill try to get u more info later. Ill try to post links with my android phone. Kinda hard sometimes. .ill do my best but honestly it would be easer if u called me.
with 03 exhaust items your coupe is probably the raspest is coupe this side of the colorado rockies
Old Dec 21, 2011 | 01:59 PM
ARKperformance's Avatar
To clarify further
Straight pipes = Testpipes
Resonated Testipes = Testpipes with Resonator
HFC (High flow Cats) = Testpipes with a higher flowing Catalytic converter
Lastly, we have ours
ARK HFC = A HFC + Chamber = No hiss or rasp with any exhaust.
Old Dec 21, 2011 | 06:22 PM
butkiss1's Avatar
There's lots of links on driver this is just 1 of them that I found. the rasp is terrible I've seen 350z's that sound like ***** . The Magna flow is your answer . You'll be happy.trust
androids suck ....ill post link in next post
Old Dec 21, 2011 | 06:25 PM
butkiss1's Avatar
https://g35driver.com/forums/intake-...t-ahhhhhh.html
