Anyone made an intake pipe themselves for the G35 Coupe?
Old Jun 26, 2016 | 08:19 AM
MurryV35's Avatar
Question Anyone made an intake pipe themselves for the G35 Coupe?
Hey guys,
I'm in Australia and looking for a cold air intake kit so i can put a pod filter/pop charger in the US? on the car to make it sound a bit better
Anyone had one custom made or made one themselves, & do they need to be made in aluminum?
I was going to see if a local exhaust shop could make one up in mild steel if that's suitable.
Cheers.
(Forgot to add, no one in Australia sells the kits for some reason - i'd have to buy one overseas)
Old Jun 26, 2016 | 12:46 PM
Lartytiejdke3's Avatar
Save yourself the headache and buy something already made for the car
It's not worth it
Old Jun 26, 2016 | 06:26 PM
gary c's Avatar
Had you read your previous post, I gave you the answer to intakes! There are no advantages to an aftermarket intake, plus there are major disadvantages to anything metal in your intake! Heat is the enemy, having metal intakes you get heat soak causing you major loss in H.P.! All you need is a Z-Tube to change the sound and a high flow drop in filter like K&N or AMSOIL!
Gary
Old Jun 27, 2016 | 02:13 AM
ScraggleRock's Avatar
Literally all you would need to do to get the most out of your stock intake tube would be to block off the baffle hole and you'd essentially have a z-tube. Like literally just duct tape over the baffle and you have a CAI.
Or just cut off the baffle and just wrap something over the hole. The baffle is the only difference between the G and Z tube.
In fact, the G-tube might be better (without the baffle) than the Z-tube cuz of the oblong chamber; It may have more complete volume. As long as it doesn't cause turbulence, it may be better.
Old Jun 27, 2016 | 03:34 AM
MurryV35's Avatar
hmm not a bad idea, what could i cover the hole with? lol
Old Jun 27, 2016 | 05:18 AM
Anything strong enough to hold up to the vacuum of the intake and the heat under the hood. Some kind of flexible plastic and silicone sealant should do the trick.
Old Jun 27, 2016 | 08:02 AM
would Bisquick work?
Old Jun 27, 2016 | 02:21 PM
Probably. Any dough would be fine, and would bake into a wonderful-smelling air freshener.
"Jerry's car always smells like fresh bread. I like carpooling with Jerry"
El_Donks
Intake & Exhaust
Apr 13, 2016 12:59 PM
SweetThuy
Apr 10, 2016 02:06 PM
nightcrawlerG
Intake & Exhaust
Mar 30, 2016 02:30 PM
bongoz
Mar 29, 2016 10:46 PM
rickybobby
Mar 29, 2016 07:24 AM
