N1 style exhaust/y pipe resonated or straight
Old Feb 10, 2018 | 07:12 PM
Melo5812's Avatar
I really wanted a top speed n1 exhaust but after calling them found out it's going to be 60 days min and maybe longer and since I don't have patience I looked around was going to buy an invidia n1 exhaust for 350z w extension pipe however the invidia has a 2.38" piping and top speed is 3" so after searching like crazy on the internet I found an exhaust by circuit werks that is the same 3" as top speed and is only $350 it's for a 350z so I'll have to buy an extension pipe don't care it's a knock off since top speed is already a knock off anyway with the $ I am saving I am thinking of buying the circuit werks y pipe my question is do I buy the resonated y pipe or the straight pipe y pipe since the exhaust already has a resonator or will 2 resonators really clean up the sound make it sound better???
Old Feb 10, 2018 | 07:42 PM
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
I have the Circuit Werks resonated Y-pipe, it definitely helped but the main issue ended up being the Tanabe exhaust itself. For a relatively quiet exhaust it has a lot of drone.
Old Feb 10, 2018 | 07:57 PM
Melo5812's Avatar
funny i I was just reading your thread lol so I have 2 choices go with the circuit weeks resonated y pipe$280 or I just found a unresonated y pipe for about $100 it's clone to the agency power one with the 3" n1 exhaust my question is resonated y pipe or straight pipe y?
Old Feb 10, 2018 | 08:10 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
You need to pay VERY close attention to inner diameter when mixing and matching components. If you step up to a large diameter, then throttle down to a smaller diameter you're going to have drone and there's pretty much nothing you can do to fix it. A well engineered system will either be the same diameter for the entire length or gradually increase (slightly) in diameter as the flow moves downstream. This is all excluding the diameter of the tip which is more for sound tuning and doesn't really affect cabin drone.
Old Feb 10, 2018 | 08:25 PM
Melo5812's Avatar
that is why I'm going to replace the y pipe so it will be 3" all the way to the mufflers from the y cuz the extension. Pipe was either 3 2.5 or 2.25 I want the 3" so I'm going to replace the y pipe but nobody has answered my question weather I should get the resonated y pipe or the straight pipe y pipe????
Old Feb 10, 2018 | 08:29 PM
Melo5812's Avatar
This is the top speed 3"
This is the circuit works 3" it's the same exact exhaust only the circuit works is high polished and I am saving over $200
Old Feb 10, 2018 | 08:33 PM
Melo5812's Avatar
This is the resonated y pipe from circuit werks it has got great reviews and is said to be extremely similar to motordyne xyz for almost half the price $289 ..resonated or straight pipe is my question
Old Feb 11, 2018 | 01:46 PM
Magneu's Avatar
5 Year Member
G35C 5AT
Minor thread hijack, but I found a way to heavily reduce drone. Found the Toyota equivalent of those rubber pucks on the HR Y-pipe (couldn't find Nissan), clamped one each between the flex-pipe and cats, and boom 90% drone gone. Sounds like it reduced a lot of the low frequencies in the exhaust that were causing the drone.
Old Feb 12, 2018 | 10:03 AM
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
Both the resonator and muffler in the Tanabe neck down considerably. Not only did replacing both with a resonator and muffler with the same diameter as the piping eliminate 90% of the drone but my car feels a bit stronger at higher rpm too.
Old Sep 22, 2020 | 01:32 AM
AvocadoOtto's Avatar
Infiniti G35 Coupe Auto Sport Suspension Upgrade in Lakeshore Slate color
[QUOTE=Melo5812;7129647]
Sorry that this is 2 years later, but did you end up getting this exhaust? If so what are your thoughts? I’m heavily considering it for my 05 coupe. Thanks!
Jamaica2G
Engine - Exhaust
Mar 26, 2013 11:00 AM
Dranom
Engine - Exhaust
46
Jan 6, 2012 09:32 PM
EvolutionGSR
Intake & Exhaust
12
Jul 9, 2008 04:50 AM
