Plenum spacer
Old May 27, 2005 | 06:52 AM
  #181
HOO-MAN?'s Avatar
Is There A Diffirence Between The Motordyne Spacer And The Hydrazine Spacer? Also ,will The 1/2 Inch Spacer Allow Me To Keep My Stock Cover In My Sedan?
Old May 27, 2005 | 09:46 AM
  #182
cato's Avatar
SouthernComfort Moderator
Hydrazine is Tony of Motordyne Engineering! Tony states that the 1/2 inch
spacer prevents the cover from being used.
Old May 27, 2005 | 10:20 AM
  #183
Memphis's Avatar
I thought the 1/2" spacer will allow the engine cover to be used in the sedan but the 1/2" spacer causes the engine cover to rub the underside of the hood on the coupe. Tony has a sedan and maybe he will confirm this. I remember in the first group buy someone was able to fit the 1/2" spacer with the engine cover easily in their sedan.
Old May 28, 2005 | 12:53 PM
  #184
Hydrazine's Avatar
Hi guys,
Yes, I do have the Sedan with the 1/2" spacer and I am using the engine cover.
I have seen that there is one small dot of contact between the engine cover and the hood insulation. It's not a problem, but at least you know it will be there.
What I recently tried is to take the rear two grommets of the plastic hood cover turn them upside down and also remove the metal standoffs. This will lower the cover a bit.
Tony
Old Jul 29, 2005 | 01:06 AM
  #185
_G_'s Avatar
_G_
Originally Posted by Hydrazine
Hi guys,
Tony
So what about the coupe? Will the 1/2 spacer fit under the hood with no contact or rubbing issues?
Old Jul 29, 2005 | 01:10 AM
  #186
Hydrazine's Avatar
The engine cover doesn't fit with the 1/2" spacer on the coup.
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
prinny
Nov 22, 2015 11:07 PM
w4kj4k
Oct 2, 2015 07:57 PM
thechitoguy
Oct 1, 2015 05:25 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
