MREV+ installed on a NON REVUP engine!
May 11, 2006 | 01:03 AM
  #286
Quote: just remembered 287hp z motor is same as 280hp g motor. duhh.
guess mrev v2 is a no go for me.
thanks Mike!
Why not?
Reply 0
May 11, 2006 | 02:49 AM
  #287
Quote: what intake are you running with this?
Weapon *R ram-air.
Reply 0
May 11, 2006 | 02:52 AM
  #288
Quote: Right on, Boris . . . Glad you are enjoying the MREV 2.
The upper collector will still be hot to the touch. However, you should have noticed that the heat is bearable, now. Just to be sure . . . The rubber insulating gasket, which came fixed to the copper plate was installed facing the plenum neck, right?
In any event, have a blast with your newest mod and try to keep the speeding down to a minimal.
Thanks for the clarification Andy. Yeah, the rubber gasket was installed facing the plenum neck.
Reply 0
May 11, 2006 | 08:12 AM
  #289
Quote: Just completed the MREV2 install on my 2005 5AT sedan. I was skeptical at first, but damn, I can certainly feel the difference throughout the revrange. It brought back some power down low, added a ton in the midrange, and keeps pulling till I hit redline. This is certainly the best bang for buck mod I have purchased.
However, my plenum is still hot to the touch after driving. I ordered the copper iso thermal 5/16" spacer and the MREV2 lower collector.
Any ideas?
Did you have a spacer before or is this the spacer plus the MREV2 lower manifold?
As for the heat, once the engine heat soaks and the underhood temps get high enough, there's no stopping heat soak on the intake manifold, regardless of the gasket setup. It's a tight engine bay that is basically sealed top and bottom.
Reply 0
May 11, 2006 | 10:26 AM
  #290
thanks Mike!
Why not? Unless you have some kind of spacer already, adding $122+ MREV2 (skip the 5/16" spacer - dont needed with MREV2) is as good as it gets - best bung for the buck.
Even if you make, very unlikely, as little as 7 WHP you will spend ~$17 per WHP.
And if you make 12+ WHP you will spend ~$10 per WHP. Not even N2O can beat this.
Reply 0
May 11, 2006 | 12:38 PM
  #291
Quote: Weapon *R ram-air.
Ahhh.... That's why its still running hot.
The WeaponR intakes draw in hot air from the engine compartment. The plenum cannot run any cooler than the air flowing through it.
Put your stock air box on and watch the plenum temperatures drop significantly.
Reply 0
May 11, 2006 | 12:54 PM
  #292
Tony doyou think this will be a problem with most of the CAI mods like the stillen?
Reply 0
May 11, 2006 | 01:00 PM
  #293
No problem with the Stillen. They have a good shroud to keep the engine compartment heat out.
For cold air induction I would rank it like this:
1) Stock
2) Stillen
3) Pop Charger
Reply 0
May 11, 2006 | 01:10 PM
  #294
Quote: No problem with the Stillen. They have a good shroud to keep the engine compartment heat out.
1) Stock
2) Stillen
3) Pop Charger
I'm looking for a JWT heat-shield for my intake, hopefully that will help keep the temps down.
Reply 0
May 11, 2006 | 02:01 PM
  #295
Got mine in today! Cant wait to get this on my car.My order number was 87 btw...
Reply 0
May 11, 2006 | 02:06 PM
  #296
dammit, now following Boris's review I want to get MREV2 as well. i may order it when i get back from vegas.
Reply 0
May 11, 2006 | 02:10 PM
  #297
Quote: dammit, now following Boris's review I want to get MREV2 as well. i may order it when i get back from vegas.
It would be interesting to see how it matches up with your Crawford plenum.
Reply 0
May 11, 2006 | 02:18 PM
  #298
Quote: It would be interesting to see how it matches up with your Crawford plenum.
indeed! this is what you bought, right?
Motordyne Modified Performance Lower Plenum for G35 - $322
Motordyne Copper Iso Thermal Upgrade Kit for G35 - $110
Reply 0
May 11, 2006 | 02:23 PM
  #299
Not quite- you can only find MREV2 on Tony's website for now. I think it's still listed as out of stock. I also have the 5/16" spacer.
Reply 0
May 11, 2006 | 02:27 PM
  #300
Quote: Not quite- you can only find MREV2 on Tony's website for now. I think it's still listed as out of stock. I also have the 5/16" spacer.
/edit http://www.motordyneengineering.com/G35.asp
how do i order an out of stock item?...
Reply 0
