MREV+ installed on a NON REVUP engine!
Old May 11, 2006 | 02:32 PM
  #301
Andy2434's Avatar
Originally Posted by codeflux
/edit http://www.motordyneengineering.com/G35.asp
how do i order an out of stock item?...
Igor,
Tony noted that the next batch will be available at the beginning of June.
Old May 11, 2006 | 03:24 PM
  #302
Aznteazer's Avatar
Originally Posted by dovla
Why not? Unless you have some kind of spacer already, adding $122+ MREV2 (skip the 5/16" spacer - dont needed with MREV2) is as good as it gets - best bung for the buck.
Even if you make, very unlikely, as little as 7 WHP you will spend ~$17 per WHP.
And if you make 12+ WHP you will spend ~$10 per WHP. Not even N2O can beat this.
yea i already have the 5/16" spacer. would have preferred the mrev v2 if i didnt have the spacer.
Old May 11, 2006 | 04:38 PM
  #303
callawayc7's Avatar
Originally Posted by andy2434
Igor,
Yeah, but will we get the same discounted price as now? I get the feeling no.
Old May 11, 2006 | 04:41 PM
  #304
Dakkerz's Avatar
What's the estimated time of installation on the MREV2? Time for me is going to be limited for me the next few weeks, just trying to find a good time to schedule this mod.
Old May 11, 2006 | 05:37 PM
  #305
TonyZ_G's Avatar
you can use the mrev v2 with the 5/16 spacer.
Old May 11, 2006 | 09:10 PM
  #306
Aznteazer's Avatar
yes but theres really no gains from it as far as the 280hp motor from the chart i looked at.
Old May 11, 2006 | 09:28 PM
  #307
TonyZ_G's Avatar
there are minimal gains.. or thats what i read before
Old May 11, 2006 | 09:51 PM
  #308
Hydrazine's Avatar
MREV2 with 5/16" spacer on REVUP ENGINE
This just came in!
The first dyno of MREV2 with 5/16" spacer on a REVUP engine.
Old May 12, 2006 | 12:14 AM
  #309
GolfHawk's Avatar
So I just finished reading this whole thread, spent 30 minutes doing so, and yet I still do not know what I can to to my 06 AT Coupe.
Can someone please tell me if the MREV works for the 06 AT, or do I just get the spacer?
Old May 12, 2006 | 01:25 AM
  #310
mikesj's Avatar
i retract my wrong comments :-)
Mike
Old May 12, 2006 | 01:31 AM
  #311
jonnylaw's Avatar
Originally Posted by mikesj
Tony just posted the dyno of mrev2 + 5/16" spacer on REVUP engine which is your car. The dyno tells you the story. The first top two curves
are mrev2+spacer and bottom three curves are stock
Mike
I thought revups are only 05-06 mt's
Old May 12, 2006 | 01:49 AM
  #312
Andy2434's Avatar
+1 . . . Good eye.
Old May 12, 2006 | 09:05 AM
  #313
LMG_35C's Avatar
So, if this plot is on the REVUP, and this thread is about NON-Revup - what's the differnce causing this dyno to look so much better? Did this REVUP have any other mods, and was it "Tuned" in any way before the MREV-2 was added? Should we expect same result on NON-Revup?
Old May 12, 2006 | 11:48 AM
  #314
Hydrazine's Avatar
Test was performed on a 350Z with Nismo exhaust and Pop charger. Nothing else.
Also, results between the nonrevup and the revup will never be the same.
The revup takes to this mod much better because the REVUP starts with a completely different plenum.
Old May 12, 2006 | 12:28 PM
  #315
LMG_35C's Avatar
..sorry if I'm not getting it but doesn't the MREV-2 and Spacer make the plenum the same for both motors now? ...or is the REVUP's variable cam timing, and perhaps differnt ECU (tuning) making the differnce.
