Removing Emblem
Old Sep 9, 2007 | 12:01 PM
wolf's Avatar
Removing Emblem
05 cpe.
If the INFINITI emblem is removed from the center of the trunk lid will there be holes left?...If there are holes for mounting studs on the emblem how does one remove the emblem?
Old Sep 9, 2007 | 12:10 PM
Chamoru671's Avatar
No holes, the INFINITI emblem is held on on by adhives.
Old Sep 9, 2007 | 12:47 PM
ndlive's Avatar
hair dryer, fishing line/dental floss, adhesive remover, strong fingers/nails
Old Sep 9, 2007 | 12:54 PM
Joaquin03's Avatar
Staff ALUMNI
goo-gone will remove the adhesive. emblem should come off the same way, only the sedan has the little bolt or mounting stud, but the coupe is just stuck on there with adhesive...
are you going to remove everything or just the INFINITI?
Old Sep 9, 2007 | 02:44 PM
quikslipper's Avatar
what kind of adhesive remover would you recommend?
Old Sep 9, 2007 | 03:44 PM
bigc's Avatar
Wings Nation
goo-gone, krud kutter, or isopropyl alcohol will all do the trick. just remember to wash the area thoroughly after you finish.
Old Sep 9, 2007 | 04:26 PM
wolf's Avatar
The emblem is all thats left...everything else is already removed. I'm making a custom front grill.
Old Sep 9, 2007 | 05:52 PM
G'd Out's Avatar
You do not even have to use a hair dryer or floss. I removed mine by pulling them off with my fingers. Floss does make it a little easier, but leaves on just about the same amount of adhesive. I then used Goo Gone to get the adhesive off. It took me about 40 minutes to remove the Infiniti and G35 symbols. Mine is an 03 and still there is no way to tell they were there, no paint fading or anything.
Old Sep 10, 2007 | 04:29 PM
WILLIE BEANS's Avatar
I Only Removed The G35 From My Rear ...
The Mt.fuji And Infinti Lettering Is Still There ..
I Think Its Looks Empty With Out The Lettering & Mt.fuji..
Old Sep 11, 2007 | 02:21 PM
G'd Out's Avatar
I have Skyline and 350GT on there along with my Infiniti symbol. I know, I know, a lot of people think you should have the Nissan symbol on there if you are going to badge it as a Skyline, but it simply looks better with the Infiniti symbol. In the end, if you really want a true Skyline, you need to purchase it and have it shipped over here. I also did the Skyline door sills.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Video Share
Jan 31, 2017 04:00 PM
dcsbh1
Oct 1, 2015 03:15 PM
