This just recently started happening. I have nothing new added on to my body. its all stock and everytime i start the engine and go in reverse or in drive the body on the right side makes a LOUD CREAKING SOUND... its soo annoying.. any ideas?
um
well i looked at it again and looks like the rear right tire area.. everytime i start driving somewhere after a while itll make the creaking sound then stop until the next time drive ..
maybe an axle click? idk what kind of creaking ur talking about? maybe your brakes are bad?
well its the type of creak youll hear when you walk over a hardwood floor or creaky stairs? its kinda hard to explain.. o.O
you know? umm ya it only makes the sound in the beginning too.
sounds eXActly like walking over creaky stairs or hardwood floors or rocking chair creaking lol
the CLicking sound got WORSE...
my friends told me it sounds like its coming from the rear right wheel axle.. is it bad?
i have the same thing but if comes from my side on the front wheel, i believe its a rubber bushing going badon control arms or something like that, i plan o going to the stealership in a few days and if i get an answer ill hit you up, it makes that sound when i stop at a light then start driving again when the weight transfers from the front to the rear and when i hit the next gear. so believe me i now what your tallking about.
hey man im going to my dealership tommorrow to get it fixed and when i get back im gonna give you the details, also there is DIY on this prob i do believe what were experiancing is a clicking axle the guy did a pretty badass write up, check it out and ill hit you up after i get back tommorrow.
well got bak from the dealer and they said it was the axle so they greased the thing inside and out, they said that infiniti used the wrong grease or some BS but anyways my creaking is gone now, i believe they just pulled the axles out and greased the shiot outta them, so my guess is do the DIY i talked about and avoid taking it to the dealer i had to wait 3 hours but i have it under warranty if you out of yours suggest DIY.
hmmmm
even with all of the DIYs out there im too scared to do it. What if I mess up on just one tiny thing. It can be a CaTASTRphE!!! :] lol I duno.
I do appreciate your feedback though thnx much man.
