Sideskirt removal how to?
Old May 10, 2010 | 04:35 PM
xXHotelCrazyXx's Avatar
To you have to remove the infiniti kick plate inside the door jam to remove the sideskirt? How easy is it to remove the sideskirt? Thanks for the help!
Old May 10, 2010 | 04:54 PM
cungkpham's Avatar
i took off my kickplate to take off the sideskirts.
There are about 8-10 screws that hold the sideskirt in place from under the bottom, about two screws on the front and rear of the sideskirts (fender) and then after you remove all the screws pull on the sideskirt outwards because they are retained by clips.
Old May 10, 2010 | 05:29 PM
ya i got it but broke some clips, but i guess thats inevitable. Thanks
Old May 10, 2010 | 05:49 PM
cdubel01's Avatar
CLUB MODERATOR
I broke some of my clips when I did mine recently too... What are u using to hold the new skirts on? I got most of the screws back in along the bottom and the front and back, but don't really want big screws going into the skirts to the side of my car? I tried double sided 3M, but that doesn't hold all that great...
Old May 10, 2010 | 07:11 PM
i havent got any new skirts yet, i messed mine up today
Old May 10, 2010 | 08:12 PM
saywat?'s Avatar
actually if u stick a flat screw driver in near the clip and yank it should pop off. its when u pull the side skirt to pop the clip off does the tearing occur. jus something i noticed when doing mine
Old May 11, 2010 | 02:21 AM
i got no tearing, just a few broken clips on each side.
Old May 11, 2010 | 02:16 PM
saywat?'s Avatar
^^yea i meant tearing = broken clips. the one that like to break is the one where that squarish pice holds the white plastic pin looking thing. that sucker tears easily
Old May 12, 2010 | 02:40 PM
Gettinby's Avatar
You arent in the market for stock sides off 05 Coupe are you ? They are BS
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Video Share
Jan 31, 2017 04:00 PM
Oregon13
Audio/Video/Electronics
Mar 1, 2016 12:06 AM
dcsbh1
Oct 1, 2015 03:15 PM
