Hood Gap
Old Jan 3, 2018 | 08:46 AM
Noure's Avatar
Hood Gap
Hello community,
I am new to the g's, I have a problem with my car
it's a 06 g35x
There is a gap between the side of the headlight and the hood
thanks for your help
Old Jan 3, 2018 | 11:50 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Possible the headlight tabs are broken (headlight assembly replaced with another one that had cracked tabs from improperly removing), also possible the hood hinge is wearing, when you open the hood does it feel like it binds up just a little bit at the back of the hood? Also possible the vehicle was damaged in an accident, remove the bumper cover and inspect closely for damage.
Does the headlight feel sort of loose? Can you wiggle it around or is it very solidly mounted?
Pictures would help also.
Old Jan 3, 2018 | 04:28 PM
Noure's Avatar
the headlights are solid, the hood align right with the fender. The previous owner had an accident but it only damaged the bumper and radiator.
Old Jan 3, 2018 | 04:44 PM
eazdaskeez's Avatar
Hmmmm maybe that's an 03-04 hood
Old Jan 3, 2018 | 04:49 PM
Noure's Avatar
Maybe, another part on the list
Old Jan 3, 2018 | 05:57 PM
cleric670's Avatar
BANNED!!!
Ok... It LOOKS like someone took a coupe front bumper and headlights and put them on a sedan. Not 100% sure what's going on in that photo though?
Old Jan 3, 2018 | 10:55 PM
G2B35AGN's Avatar
I think you have it a bit backward. Those are certainly sedan headlights; I'll bet it's a coupe hood. That's a guess; haven't compared any pics. Also, that's a sedanX bumper. The third hole centered low is the giveaway.
Old Jan 4, 2018 | 08:54 AM
Blue Dream's Avatar
I drove ttrank's car solo
^^This. It's an 05-06 SedanX. If the hood was 03-04 sedan it'd have that slight cowl look in the middle with 2 defining lines r/l of center that is raised slightly in the middle. The 05-06 hood has a slight raised line in the middle that runs front to back. I see none of those and the bumper gives away an X model as said above, unless it's been replaced on a non-X model.
Old Jan 7, 2018 | 10:56 PM
Eye Eat Ketchup's Avatar
yeah those guys are right. it's definitely sedan headlights. must be coupe hood since blue dream is right about the sedan hoods.
Old Jan 9, 2018 | 12:34 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
Yep. Coupe hood. So the previous owner lied his pants off when selling it. Hopefully that's all they lied about.
Old Jan 9, 2018 | 07:08 AM
ScraggleRock's Avatar
Lmao
Old Jan 9, 2018 | 10:12 AM
Noure's Avatar
Originally Posted by wrathernaut
yep. Coupe hood. So the previous owner lied his pants off when selling it. Hopefully that's all they lied about.
Old Jan 9, 2018 | 11:35 AM
cleric670's Avatar
BANNED!!!
OP you can make a "band-aid" if getting a new hood is not an options right now, look into getting coupe "eyelids" adhere them to your light and use them to fill the gap temporarily until you are able to get the correct hood.
Ionic Dynamics ones fit pretty good and you can even order them painted.
http://www.ionicdynamics.com/G35EYElids.html
Jahaaji
May 23, 2012 06:29 PM
krypton
Jun 11, 2010 02:04 AM
skaline
Apr 23, 2004 07:01 PM
ChuckV
Feb 8, 2004 01:36 PM
