Window issues!!!!!!
Old Jul 2, 2019 | 01:14 PM
Dom_35's Avatar
03 G35 coupe
Window issues!!!!!!
I have a 2003 G35 coupe with serious window issues Ive basically done everything possible to trouble shoot these issues! Both window motors are good are Ive done the reset procedures multiple times. anything would help me, ive been stuck not able to drive the windows are stuck in the down position and due to the rapid weather changes here in FLORIDA where one second its sunny then starts Pouring im unable to drive places in fear of getting caught in the rain Thanks in advance!!!
Here is my G35 coupe!!
Old Jul 3, 2019 | 06:33 AM
Scorpi0's Avatar
Im assuming that car is on airbags or else that thing would be impossible to drive anywhere.
Anyway, u didnt tell us anything about what the windows are actually doing. Give us some details. What happens when u try to move em?
Old Jul 4, 2019 | 01:30 PM
Dom_35's Avatar
03 G35 coupe
Nothing happens when you push the buttons, the passenger one works until the window goes all the way down. then it doesn't work we have changed the locks and window motor still not working have tried to reset them and still nothing.
Old Jul 4, 2019 | 01:32 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Take off the door panel, the inner panel, unplug the harness from the window motor. Use a digital multimeter and read voltage across the two pins of the harness, up should be +12v dc, down should reverse polarity to -12v dc.
If you have voltage then you probably have bad motors (check both doors, you might have a broken wire in one of them at the hinge), if you DONT have voltage then you might have a bad switch, broken wires, bad BCM, etc.
Old Jul 4, 2019 | 01:36 PM
cleric670's Avatar
BANNED!!!
Also, you can roll the windows UP and DOWN by putting hte key in the door lock and holding it to the locked position (up) or unlocked position (down). I think this can be done to bypass the door switch which would help troubleshoot if it has failed.
Old Jul 5, 2019 | 01:04 PM
Urbanengineer's Avatar
Great idea!
Old Jul 5, 2019 | 02:07 PM
cleric670's Avatar
BANNED!!!
I'm not totally sure if the signal comes back from the BCM through the driver window switch though, it's the master switch but I THINK all the power signals are straight from the BCM to the window motors.
TheFresh
Jan 14, 2011 08:02 AM
blownvert
Mar 11, 2008 09:51 PM
dennis_said
Apr 15, 2005 04:13 PM
justinmehta
Sep 9, 2003 02:46 PM
