couldnt lift car because of body kit...
Old May 31, 2005 | 06:21 PM
BLacK_G35_CouPe's Avatar
the dealership couldnt lift my car because of my body kit...my car isnt lowered at all...could someone suggest what to do? they did not specify wut part of the body was holding it back...im guessin the sideskirts? but id appreciate any suggestions...thnx
Old May 31, 2005 | 06:24 PM
jdbinspired's Avatar
those guys were probably just lazy... Usually the techs would lift it from the back with a floor jack... then insert the lift arms behind the front wheels... that's how they usually work it...
Old May 31, 2005 | 06:41 PM
yea i figured if they went through enough training to work there...somewhere in the training a car with a body had to have been seen lol...the thing that pissed me off is i dropped the car off at 8 am...called them 3 times...and he said he would call back...than i called a 4th time, and he left...so i really dont know wut his deal is...but ill be sure to find out tomorrow morning...thnx again
Old May 31, 2005 | 07:29 PM
Cuda's Avatar
well at home... we run the car on bricks... then lift...
Old May 31, 2005 | 10:28 PM
TINMAN's Avatar
you didn't say what body kit you have..anyway 1st to try is use small floor jack.if that not work drive the car on some blocks.
Old May 31, 2005 | 10:35 PM
ducatiguy's Avatar
Premier Dough Slapper
Surprised what a 2x4 can do! Anyhow, just a note, if you have Greddy side skirts and or similar, you WONT be able to use your factory jack either! Sucks when you're on the side of the road with a flat and you cant get your car up...
Old Jun 1, 2005 | 08:13 AM
JDM 350GT's Avatar
+1...i was curious;
Old Jun 1, 2005 | 08:22 AM
pdjafari's Avatar
I have seen a racing jack which has a low profile and can fit under lowered cars...anyone running one of those?? My car is stock height but the splash guard gets in the way at times so I have to remove the head on the jack and use a 2x4 at times to get her up!
Old Jun 1, 2005 | 10:34 AM
GT-Ron's Avatar
These are all great solutions for working at home or if you have access to a shop with a lift, but that's still not going to solve the problem when he goes to have the car serviced somewhere. Hopefully there will be a sharp tech around that knows how to get the car up.
My '97 Mitsu. GSX was lowered, with the OEM bodywork, and I ran into clearance problems with lifts and oil-change-pit raised edging. Ended up finding a garage/gas station close to work who had a low enough profile lift to accomodate the car. You could look for the same.
I'm going to try to avoid lowering my G. I'll look for the minimum drop if the fender gap is just too much to stand, especially since I'll be running the Nismo front bumper. But I'd rather have the ground clearance. That GSX always posed a problem when trying to load, lift or traverse speed bumps and (not-so) steep driveways. Suddenly having a rock or chunk of wood reveal itself from the car in front of you, on the highway with nowhere to go but over it, could be an intensely sphincter-puckering moment.
Old Jun 1, 2005 | 12:29 PM
im heading there right now...i have the AIT bodykit...they told me i could take off the parts that would scratch, so im goin to take the side skirts off for sure, but not sure about the front bumper...thnx for the advice, i will be going over there with some 2x4s, and my friends jack...which they probably already have there...ill let you guys know about the out come...thanks for the advice...
Old Jun 1, 2005 | 12:34 PM
pfizzle's Avatar
Remove your kit and take it in for service, thats what I used to do with my Accord.
Why were you going to the dealership anyways?
Old Jun 2, 2005 | 12:40 AM
i had to take off the side skirts before they worked on it...atleast i know now...i had to get a new rear axle joint installed...becuase of some clickin issues in the rear...and i figured while it was there ill get an oil change too...but now everyone knows...if ur car is too low, take off ur side skirts before u go to the dealer...im riding stock height, so didnt think it would be an issue...thnx again...
chinee
Jun 10, 2024 07:48 PM
Hasanbaloch
Feb 29, 2024 08:45 PM
keresa777
Jul 27, 2015 09:04 AM
Frostbite91
Jul 27, 2015 05:25 AM
