blown fuse
Old Oct 4, 2005 | 10:57 AM
briphi's Avatar
blown fuse
Doing some work last night shorted the sidemarkers out, and am pretty sure that I just blew their fuse. I have the service manuals and I've looked through them, but I've found it quite confusing. Does anybody know what # fuse I need to replace, or how to find out?
Old Oct 4, 2005 | 11:06 AM
PeteNJ's Avatar
I thought you were a l33t engineer? Didn't they cover that in engineering 101? Open up the fuse box and LOOK.
Old Oct 4, 2005 | 12:31 PM
briphi's Avatar
Well Pete, there are 3 fuse blocks with a total of 80 fuses or so- and since I'm not that familiar with car fuses, I'm not sure if you can easily and visually identify which one is burnt out. Of course I'm going to look around and try to find it where I think it is, I just asked in the meantime if anyone knew off hand.
Old Oct 4, 2005 | 05:01 PM
PeteNJ's Avatar
Like I said look in the fuse box. It tells you what fuses to use and also has spares. Cmon Mr.Engineer even my grandmother knows this.
Old Oct 4, 2005 | 05:21 PM
tony's Avatar
For the side markers I'm not sure.. I blew the fuse for the stock high beams and that one is behind the battery. I'll try and look the info up for you when I get home.
Old Oct 4, 2005 | 05:50 PM
PeteNJ's Avatar
There is a fuse for the clearance strip.,sidemarkers, and taillights. It is located in the 3rd fuse box behind the battery.
Old Oct 4, 2005 | 06:47 PM
tony's Avatar
by chance would you know where the fuse is for the fog lights?
Old Oct 4, 2005 | 07:32 PM
EricIsKlumzyee's Avatar
i gave a friend the wiring diagram for the G35c lights and headlight diagram.. im not 100% sure but that might have the fuse locations..
so *bump.. hopefully he'll see it when he gets home
Old Oct 5, 2005 | 12:32 AM
accordfreak's Avatar
it's behind the battery. you have to take off the whole battery cover.. about 5 clips.. then take off the cover against the firewall/windshield (2 clips) AFter that you can access the fuse box behind the battery. it has all the lighting fuses.
Old Oct 5, 2005 | 12:24 PM
briphi's Avatar
Thanks for the help guys
Old Oct 6, 2005 | 02:32 AM
drsifu1's Avatar
Staff ALUMNI
20 Year Member
read this thread
https://g35driver.com/forums/engine-drivetrain-forced-induction/69048-ahh-please-help-fuse-blow-car-fuked.html
vinh
Learned Hand
Oct 1, 2015 09:02 AM
yosip1115
16
Sep 28, 2015 04:14 PM
2014g35x
Sep 11, 2015 07:53 PM
