LED under glove box/steering wheel help
Old Nov 17, 2010 | 06:44 PM
  #226
toymachine2009's Avatar
I had this professionally done with the CCFL tubes. So its a clean install and all wires are ran under the carpets and nothing is visible anywhere.. I had them set it up where it comes on when doors open and also I had them install a manual switch so I can turn them on and off as I please or I can just leave it off and let it come on automatically when doors open and close.
Old Nov 17, 2010 | 06:52 PM
  #227
zoop425's Avatar
you probably way over paid.. this is an easy thing to do yourself
Old Nov 17, 2010 | 07:02 PM
  #228
ChinkyChoy's Avatar
Originally Posted by TripleHBK
1) What Gauge of wire did you use for the extension?
2) Care to explain how you wired these into the fuse panel? I was under the assumption that these would just be installed the same way as the CCFLs...
Originally Posted by pythonjosh
1- 16ga wire.
2- Wire them into a circuit, all of which have a fuse, pick one that isn't used for a critical part of the car.
I chose to run a new wire from the battery to a fuse distribution block. Completely independent of the car.
Sorry havent responded in forever been busy!
yeah pretty much what he said i think i picked the door light fuse so when my doors are open the lights come on i ll take a picture of my fuse panel this weekend if i can remember. its only cause the 2nd gen sedans are different than the ones posted earlier in the thread.
Old Nov 20, 2010 | 01:23 AM
  #229
salamsg35's Avatar
hello guys ok so i bought LED strip light and im trying to install them under steering wheel and under glove compartment on my 03 Coupe The wires from the picture posted were different than what i have are they the same on 03????, but i tried and i got my LEDs to go on but they were not bright like they should they are 12volt LED and they worked when i checked them on my car batter So pleas help ?? what should i do and where do i connect them ??
Old Nov 20, 2010 | 01:25 AM
  #230
salamsg35's Avatar
Originally Posted by MYG35IZSICK
man thanks alot guys, i figured it out myself.
Hello man i have the samething what did u Do or which wires did u use...
Im using LED strip Will it work ok???
pictures if u have pleas?
Old Nov 20, 2010 | 01:33 AM
  #231
salamsg35's Avatar
[QUOTE=ChinkyChoy;5487716]Sorry havent responded in forever been busy!
yeah pretty much what he said i think i picked the door light fuse so when my doors are open the lights come on i ll take a picture of my fuse panel this weekend if i can remember. its only cause the 2nd gen sedans are different than the ones posted earlier in the thread.[/QUO
Hi looks like u have done this mod?.
would it work with LED strip lights, what wires should i connect it too on 03 coupe. ??
Old Nov 20, 2010 | 08:45 PM
  #232
ChinkyChoy's Avatar
hmm i am not sure about an 03 but my best bet would be to connect it to the dome light wire so that when your door is open the lights will light up too. that is how mine is set up
like i said i have no idea for the 1st gen G's also if you scroll back a couple pages you can see what kind of LED strip i bought.
Old Nov 20, 2010 | 08:56 PM
  #233
WhosRich's Avatar
LED strip lights would work too.
Old Nov 20, 2010 | 08:57 PM
  #234
Funny since got it done free! There on there own fuse too so if they blow I just change the fuse and its only too those lights
Old Nov 20, 2010 | 10:06 PM
  #235
salamsg35's Avatar
thank u guys,, i kept trying and i found wire that work with dome light but the LED light was not bright any Ideas???
Old Nov 20, 2010 | 11:28 PM
  #236
pythonjosh's Avatar
led's need the least power of any light emitting electrical device.
If they are not bright, wire them to another circuit in the car, like the cigarette lighter, just for testing to see if they are actually bright.
Or, you may be experiencing what I did with mine. I found that the ground wire for the dome light (door sensors) is that it is not a good solid connection to ground. But this resulted in a light that wouldn't stay bright, and wouldn't stay off, it would always flicker.
For this, I have not yet found a solution to as I don't know if it's just my car, or if all G's are like that.
Let me know, and I and others can work on that.
Old Nov 21, 2010 | 01:02 PM
  #237
salamsg35's Avatar
yes i test the LED they are bright, and what i did is i kept trying all the bulges and i found the wire works with the dome light and it would always flicker. I didnt know what you really did with the + and -. i didnt get it ?
Old Nov 22, 2010 | 04:11 AM
  #238
pythonjosh's Avatar
If you got them to light you got the positive and negative right.
Old Nov 30, 2010 | 04:33 AM
  #239
NVM's Avatar
NVM
I got my driver's side wired up, but how did you guys end up running the wires over to the passenger side?
Old Nov 30, 2010 | 04:44 AM
  #240
pythonjosh's Avatar
I snaked them under the head unit. Used a clothes hanger to send it thru then pull the wires thru.
